Guest WALFY Posted August 21, 2008 Share Posted August 21, 2008 I've finaly fitted my turbo that I purchased from Mo back along. This entailed changing the front timing chest. In effect I have converted my Disco 200TDI to DefenderTDI. Front chest, manifolds, PAS etc. The problem I now have is that there is an oil leak through the chest via the tensioner pulley. I confirmed this by taking the front cover off and running it for a few minutes. Oil appears on the front edge of the pulley and drips from the back edge. The bolt goes right through to the block. I've tried taking it off and putting a blob of mastic on the bolt and buttoning it all up. The mastic slowed the flow but didn't cure the problem. My next option is to use tiger seal rather than mastic. After comparing the Disco chest there are no other ways of it comimg through. The cam seal is dry as is the crank seal. I can see no other way of the oil coming through. Does anyone have any ideas of how to cure the leak. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 21, 2008 Share Posted August 21, 2008 I've finaly fitted my turbo that I purchased from Mo back along. This entailed changing the front timing chest. In effect I have converted my Disco 200TDI to DefenderTDI. Front chest, manifolds, PAS etc.The problem I now have is that there is an oil leak through the chest via the tensioner pulley. I confirmed this by taking the front cover off and running it for a few minutes. Oil appears on the front edge of the pulley and drips from the back edge. The bolt goes right through to the block. I've tried taking it off and putting a blob of mastic on the bolt and buttoning it all up. The mastic slowed the flow but didn't cure the problem. My next option is to use tiger seal rather than mastic. After comparing the Disco chest there are no other ways of it comimg through. The cam seal is dry as is the crank seal. I can see no other way of the oil coming through. Does anyone have any ideas of how to cure the leak. Bit kludgy but PTFE tape on the threads might do it, provided you make sure there aren't wispy bits dropping where they shouldn't? Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 22, 2008 Share Posted August 22, 2008 Hadn't considered PTFE tape. I was just going for the big slpodge of tiger seal. Thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted August 22, 2008 Share Posted August 22, 2008 Take the bolt out and throw it away. Then it won't be a leak, it will be an oil gallery Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 22, 2008 Share Posted August 22, 2008 Take the bolt out and throw it away. Then it won't be a leak, it will be an oil gallery Thanks . Then the timing belt would get a wee bit oily. At least the engine would get a regular oil change. About every tank of fuel Quote Link to comment Share on other sites More sharing options...
draper40 Posted August 22, 2008 Share Posted August 22, 2008 WALFY, As you know I had the same problem, just been out and PTFE'd the thread, no sign of oil!(yet!!!) Pete Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 22, 2008 Share Posted August 22, 2008 Same here. PTFE on the bolt, and a smear of silicon on th back of the idler. Buttoned it all up. But won't run it till tomorrow night. Give it all chance to seal properly. Well that's the idea anyway. Will run it up after I get back from my tour of the Dealerships tomorrow. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 23, 2008 Share Posted August 23, 2008 Pete How did you get on? Any oil yet? Not run mine up yet Quote Link to comment Share on other sites More sharing options...
