Guest WALFY Posted August 27, 2008 Share Posted August 27, 2008 It runs!!!!! Chris turned up after it was running. The feed wire from the flux capacitor had come loose and was earthing the oojamaflip. Once that was sorted it fired up straight away. Whatever Chris says He came after it was started and drank all my tea and ate all the jaffa cakes . I'll let Chris elaborate on his theory . But it's all lies I tell you Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 27, 2008 Share Posted August 27, 2008 I do not know about getting there after it started running, you seem to have some problems with your 'timing' Mark. Glad it is all OK now. Chris Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 27, 2008 Share Posted August 27, 2008 Once again, many thanks Chris. I'd of been there all day otherwise Quote Link to comment Share on other sites More sharing options...
JST Posted August 27, 2008 Share Posted August 27, 2008 come on then tell all so we dont all fall fowl of the timing beast Quote Link to comment Share on other sites More sharing options...
GBMUD Posted August 27, 2008 Share Posted August 27, 2008 In short, as well as finding TDC on the crank and aligning the cam shaft index mark with the arrow, you have to get the timing pin through the FIP wheel in the same place as the recess in the front of the FIP housing - rather than at 240degrees from it. Chris Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 27, 2008 Share Posted August 27, 2008 In short, as well as finding TDC on the crank and aligning the cam shaft index mark with the arrow, you have to get the timing pin through the FIP wheel in the same place as the recess in the front of the FIP housing - rather than at 240degrees from it. Chris 240 deg . You went the long way round then . Only a little way off. See what I said Lies all lies Quote Link to comment Share on other sites More sharing options...
Orange Posted August 27, 2008 Share Posted August 27, 2008 So I wasn't far off with my 180 degrees, then..........albeit at the wrong end of the engine!!! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted August 27, 2008 Share Posted August 27, 2008 Adrian I'll explain when we see you next. When ever that'll be Quote Link to comment Share on other sites More sharing options...
BLACK CAB Posted August 27, 2008 Share Posted August 27, 2008 Mark, at least you know how to Time it up now ..........240 deg . Quote Link to comment Share on other sites More sharing options...
