daverangerover Posted August 31, 2008 Share Posted August 31, 2008 runs ok on gas,wont start on petrol but tries,runs when switched over from gas,but wont rev,dies when throttle touched,screw on air flow meter has been messed with and screw on throttle body,were do you start,thought it was fuel pump, fitted new one as well as fuel line,is the meant to be 3 relays under drivers seat,there is 2 and one missing,any info really appreciated . Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted September 1, 2008 Share Posted September 1, 2008 OK what is it? What age and engine? Have a look at the "bible" in the tech archive for fault finding Efi systems. My 1989 Efi has 3 relays under the drivers seat., one is for the fuel pump. Can't remember what the others do, and am at least 500 miles away from being able to have a look. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 1, 2008 Share Posted September 1, 2008 The three relays are: Fuel pump (will have a white/purple wire coming out of it) Main relay (lots of brown wires) the ECU won't work without it Steering module - this is the red plastic one, it contains the parts they forgot to build into the ECU (no, really!) and does a few little things like keeping the fuel pump on whilst cranking. They do go faulty but the component parts inside them are pennies. Quote Link to comment Share on other sites More sharing options...
NRS91 Posted September 1, 2008 Share Posted September 1, 2008 same prob on mine... bottom plug on back of alarm on drivers wing was loose...try that thanks Nick Quote Link to comment Share on other sites More sharing options...
daverangerover Posted September 1, 2008 Author Share Posted September 1, 2008 mine has 2 relays,the main one with thick wires,the red one,and one missing with a few 4or 5 white wires going to it,should there be a relay in it,its a 1989 vogue sei 3.5i, Quote Link to comment Share on other sites More sharing options...
daverangerover Posted September 1, 2008 Author Share Posted September 1, 2008 same prob on mine...bottom plug on back of alarm on drivers wing was loose...try that thanks Nick going to remove alarm,air horns going,air con gone,what is not getting used is going in the bin, Quote Link to comment Share on other sites More sharing options...
