Paul Humphreys Posted September 2, 2008 Share Posted September 2, 2008 Of this Rope? I am thinking of getting some as I only use my winch about once every 6 months or so or stick with the wire rope? Paul Quote Link to comment Share on other sites More sharing options...
white90 Posted September 2, 2008 Share Posted September 2, 2008 I still have your brand new wire rope here Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted September 2, 2008 Author Share Posted September 2, 2008 I still have your brand new wire rope here I know, I had sort of given up on that one!! But I will have to sort it out some time. Paul Quote Link to comment Share on other sites More sharing options...
treebloke Posted September 2, 2008 Share Posted September 2, 2008 £146 plasma against £20 for steel to use twice a year. 10mm will not be strong enough for that sherman you drive anyway. If your going to plasma, better to be on top of the job than underneath it. Might be better with a shorter 12mm than a long 10mm. I have had cheap plasma and it did not perform as good as the well known brands. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted September 2, 2008 Author Share Posted September 2, 2008 £146 plasma against £20 for steel to use twice a year.10mm will not be strong enough for that sherman you drive anyway. If your going to plasma, better to be on top of the job than underneath it. Might be better with a shorter 12mm than a long 10mm. I have had cheap plasma and it did not perform as good as the well known brands. Thats what I wanted to hear Bob. Sherman, not quite that bit, but I bet its getting on for 4T now!! Paul Quote Link to comment Share on other sites More sharing options...
v8bertha Posted September 2, 2008 Share Posted September 2, 2008 For twice a year usage I'd stick with the wire cable if that's what you currently have fitted. Obviously there are pros and cons of each, but providing its properly maintained and not kinked and used within its safety parameters, then a wire rope should be fine. I vaguely recall a thread about this some time ago... sure somebody who knows how to use the search falicity properly will be able to find it and link it. Dan Quote Link to comment Share on other sites More sharing options...
treebloke Posted September 2, 2008 Share Posted September 2, 2008 Thats what I wanted to hear Bob. Sherman, not quite that bit, but I bet its getting on for 4T now!! Paul 4 tonne, do you carry a suzuki in the back in case you break down. Quote Link to comment Share on other sites More sharing options...
