3.9 disco manifolds on Def90 conversion?
Has anyone got 3.9 manifolds from a Range Rover or Disco on a 3.5 in a 90?
Are there any clearance issues if i use these, and is there actually any palpable benefit over the older style 4into1 manifolds?
Just working everything out before i do the conversion.
I have a 3.9i in my 110 with the efi manifolds, no probs, it was a v8 3.5 from the factory , so dont know if that helps you was yours a factory V8 90 ?
Its a job to say if they help re power to any extent as the engine was more powerful anyway.
Whether its worth the hassle with a 3,5 is debatable.
A proper multibranch manifold in stainless probably would be JMHO HTSH
It is a 2.25 from the factory- the 3.5 is currently being built to go in sometime over the next month or two.
I have later 10 bolt heads to go on the block, and as these are more free flowing (bulleted valve guides, wasted stem valves and larger ports) it would be a shame to strangle them with an early exhaust if the later design is better.
