macandrc Posted September 3, 2008 Share Posted September 3, 2008 Evening all, i have got an electrical gremlin on my 90 which i have just rebuilt, the radio cuts out any time that i turn on the lights, press the brake peddal, put in th eindicators, etc... any ideas? i have tried wiring the radio directly to the battery but get the same fault. its an 1986 90 colin Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 3, 2008 Share Posted September 3, 2008 Or to put it another way.... In case you havn't guessed..... Earth Must be something to do with the lights, if you've connected the stereo directly to the battery. check the bulkhead earth is connected (or just fit ojne, for peace of mind) Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 3, 2008 Share Posted September 3, 2008 In other words you need a wire from the radio chassis to a good earth on your lr. Make it black. Quote Link to comment Share on other sites More sharing options...
macandrc Posted September 3, 2008 Author Share Posted September 3, 2008 Thanks guys will get on it. colin Quote Link to comment Share on other sites More sharing options...
Clive D Posted September 18, 2008 Share Posted September 18, 2008 Thanks guys will get on it.colin Did it work? I've just fitted LED front side-lights and have exactly the same issue - and having done a bit of a search it seems it is fairly common, and that most people just give up and take them out. Surely there must be a fix....? Quote Link to comment Share on other sites More sharing options...
western Posted September 18, 2008 Share Posted September 18, 2008 some led bulb units are connected differently in there casing to normal bulbs, one fix is to swap the wiring on the light units over. Quote Link to comment Share on other sites More sharing options...
macandrc Posted September 19, 2008 Author Share Posted September 19, 2008 Did it work? I've just fitted LED front side-lights and have exactly the same issue - and having done a bit of a search it seems it is fairly common, and that most people just give up and take them out. Surely there must be a fix....? only just got back from holiday so havent had a chance to have a look and will let you know. will try earthing directly from the bulkhead to the negative terminal on the battery. colin Quote Link to comment Share on other sites More sharing options...
Dave K Posted September 19, 2008 Share Posted September 19, 2008 This might help. http://forums.lr4x4.com/index.php?showtopi...p;hl=LED+lights Quote Link to comment Share on other sites More sharing options...
macandrc Posted September 19, 2008 Author Share Posted September 19, 2008 This might help.http://forums.lr4x4.com/index.php?showtopi...p;hl=LED+lights Fixed the problem, i ran a direct earth tot he negative ont he battery fromt he radio and all is working fine now. thanks for the advice colin Quote Link to comment Share on other sites More sharing options...
