fender1234 Posted September 9, 2008 Share Posted September 9, 2008 hi, whilst the gearbox is off being rebuilt i noticed a little puddle of engine oil on the floor, which it looks to me like it weeping around where the flywheel housing joins the engine. My theory is thats its weeping out because the engine tipped right back because the gearbox isnt on. anyone have any ideas on the situation? thanks Quote Link to comment Share on other sites More sharing options...
hattymender Posted September 9, 2008 Share Posted September 9, 2008 What engine? Mind you, they all leak............. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted September 9, 2008 Author Share Posted September 9, 2008 What engine? Mind you, they all leak............. disco 200tdi Quote Link to comment Share on other sites More sharing options...
LZ5UL Posted September 9, 2008 Share Posted September 9, 2008 Rear crankshaft seal ? Quote Link to comment Share on other sites More sharing options...
fender1234 Posted September 9, 2008 Author Share Posted September 9, 2008 Rear crankshaft seal ? i took the flywheel off and theres no mark off oil leaking from it Quote Link to comment Share on other sites More sharing options...
hattymender Posted September 9, 2008 Share Posted September 9, 2008 Oil or clutch fluid? Has slave pushed piston out? Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2008 Share Posted September 9, 2008 might be from a loose sump or ladder frame bolt orbell housing bolt. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted September 9, 2008 Author Share Posted September 9, 2008 Oil or clutch fluid? Has slave pushed piston out? 99.9% its oil Quote Link to comment Share on other sites More sharing options...
fender1234 Posted September 9, 2008 Author Share Posted September 9, 2008 might be from a loose sump or ladder frame bolt orbell housing bolt. what is orbell housing bolt? Quote Link to comment Share on other sites More sharing options...
western Posted September 9, 2008 Share Posted September 9, 2008 what is orbell housing bolt? OOPS should say flywheel housing [the big bit that bolt to the engine block] Quote Link to comment Share on other sites More sharing options...
fender1234 Posted September 9, 2008 Author Share Posted September 9, 2008 just realised what you meant how do i find the ladder frame bolts? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 10, 2008 Share Posted September 10, 2008 A lot of the sump bolts are also the ladder frame bolts, but there are a few others outside of the sump pan lip that hold it on by themselves - 5-more on a Disco engine if I remember right. Les. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted September 10, 2008 Author Share Posted September 10, 2008 A lot of the sump bolts are also the ladder frame bolts, but there are a few others outside of the sump pan lip that hold it on by themselves - 5-more on a Disco engine if I remember right. Les. thanks Les i'll go see if can work it out Quote Link to comment Share on other sites More sharing options...
