Exmoor Beast Posted September 17, 2008 Share Posted September 17, 2008 How much play should there be in the VC support bearings? I was giving the Freelander the once over at the weekend and having thought I detected a touch of vibration last week (paranoia?)I gave a propshafts a good shake to see if there was any play in the UJs. I was amazed at how much the bearings each side of the VC moved, I had expected them to be rock solid but they moved a hell of a lot. Will Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 17, 2008 Share Posted September 17, 2008 Aren't they rubber-mounted? Quote Link to comment Share on other sites More sharing options...
Exmoor Beast Posted September 18, 2008 Author Share Posted September 18, 2008 Yeah but I was amazed they moved so much, I thought they would be reasonably rigid. Will Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted September 18, 2008 Share Posted September 18, 2008 Yeah but I was amazed they moved so much, I thought they would be reasonably rigid.Will Hi The one I drive has perished support bearing rubbers, this causes a knocking noise on over run and sharp turns so I'm having them replaced in the next few days. It sounds like yours may be getting a bit soft too. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 18, 2008 Share Posted September 18, 2008 The knocking noise if you come off the power sharply is usually the rubber rear diff mountings rather than the VCU bearings. VCU bearings make a loud "rubbing" noise when they are kaput, which increases with speed. Quote Link to comment Share on other sites More sharing options...
thirstybeast Posted September 18, 2008 Share Posted September 18, 2008 I think I have more than one fault then! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 19, 2008 Share Posted September 19, 2008 Could be down to the previous owners being a bit rough Quote Link to comment Share on other sites More sharing options...
