Bobtail Posted September 18, 2008 Share Posted September 18, 2008 I have a RRC fitted with 200tdi and LT77 from a 91 disco I have fitted 35x12.5x15 creepy crawlers Which Transfer box will i need to put on to get the gearing back to somewhere near standard Cheers Jim Quote Link to comment Share on other sites More sharing options...
teslo Posted September 18, 2008 Share Posted September 18, 2008 I would say that 1.4 ratio will be fine. Quote Link to comment Share on other sites More sharing options...
Escape Posted September 18, 2008 Share Posted September 18, 2008 Remember a different transfer box will only affect high gear, if you want to lower your gearing in low gear as well you'll have to change the ring&pinions or fit an underdrive... Quote Link to comment Share on other sites More sharing options...
chris200100 Posted September 25, 2008 Share Posted September 25, 2008 bobtail, Did you have to do many mods like a body lift etc to get 35" on you rangie???? Quote Link to comment Share on other sites More sharing options...
Young bobtail Rhys Posted September 25, 2008 Share Posted September 25, 2008 Any more info just pm me instead of going too off topic, but I have a 70mm spring lift of my rangie, +50mm extended arches and thats all, running on 35/13.5 mickey thompson's. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted September 25, 2008 Share Posted September 25, 2008 to get your gearing back on track with 35,s you really need a1.6:1 which was fitted to 110 2.5 nad.contrary to a reply posted all low range gears have the same low ratio.chris. Quote Link to comment Share on other sites More sharing options...
