Juz Posted September 23, 2008 Share Posted September 23, 2008 Right, so the problem definitely was the fuel stop solenoid. I bought a new one but it doesn't fit quite right. Fully tightened, the plunger cannot move enough to allow any fuel to pass - the engine does not start. Loosened of a couple of turns, the engine starts and stops ok, but doesn't allow enough fuel to flow to rev properly. Loosened another couple of turns, the engine starts, stops and runs properly, but diesel leaks from around the solenoid. BUGGER!!!! Can I fix this by putting PTFE tape around the threads or am I cocking something up here? Juz Quote Link to comment Share on other sites More sharing options...
western Posted September 23, 2008 Share Posted September 23, 2008 which engine are we dealing with here ? ignore the above, just read yopur previous post & left a reply there. Quote Link to comment Share on other sites More sharing options...
bow Posted September 23, 2008 Share Posted September 23, 2008 please, do not use ptfe tape or paste, it does not react well to diesel or petrol, once the ptfe breaks down due to the fuel it can cause major problems with your fuel system, once had some socalled fitter do this on an old fork truck , and it buggered the pump, try and get the propper switch, a bodge will only come back and haunt you, ATB, BOW.. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 24, 2008 Share Posted September 24, 2008 There should be a sealing washer with the switch. If it's there, just add another one. Les. Quote Link to comment Share on other sites More sharing options...
Juz Posted September 25, 2008 Author Share Posted September 25, 2008 So, PTFE tape is a NO-NO. Option 1 then is a thicker O-ring. If that fails is there another type of tape that I could use to seal the threads? Juz Quote Link to comment Share on other sites More sharing options...
Juz Posted September 26, 2008 Author Share Posted September 26, 2008 So, PTFE tape is a NO-NO.Option 1 then is a thicker O-ring. If that fails is there another type of tape that I could use to seal the threads? Juz Or, where can I get the original Bosch part from? Juz Quote Link to comment Share on other sites More sharing options...
Steve Warman Posted September 26, 2008 Share Posted September 26, 2008 Hi Juz, Give Dingocrofts a call in downley. They've always managed to source parts for me before at a reasonable price and speed. Steve Quote Link to comment Share on other sites More sharing options...
Juz Posted September 26, 2008 Author Share Posted September 26, 2008 Hi Juz,Give Dingocrofts a call in downley. They've always managed to source parts for me before at a reasonable price and speed. Steve They've got a part but it's not the Bosch. Maybe I just need to try it though. Juz Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 26, 2008 Share Posted September 26, 2008 Fuel cut-off switches are a commonly available part from most good motor factors - you shouldn't have any problems with getting one. Bosch/Intermotor/NipponDenso/etc are popular makes. Les. Quote Link to comment Share on other sites More sharing options...
