kevinr Posted September 27, 2008 Share Posted September 27, 2008 Following a mishap today..thanks to some t**t, I've bent the track rod (the rear one attached to the steering damper..I presume it's a track rod). This makes steering a bag of laughs, but can it be straightened succesfully, if so how..or am I looking at sourcing and buying a replacement? I've jacked a ball join seperator bar between the axel and the bent bar, forcing into shape..or at least a better one. Is this likely to end in failure, or will several hours like this, force the it back? Quote Link to comment Share on other sites More sharing options...
landmannnn Posted September 27, 2008 Share Posted September 27, 2008 Buy a new one. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted September 27, 2008 Share Posted September 27, 2008 Even if you can get it straight it will bend again next time... Once they are bent they are scrap and should be replaced. You can always use it as an excuse to go for an uprated one! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 27, 2008 Share Posted September 27, 2008 Once bent, they will bend again easily. New ones are dirt cheap - even heavy duty ones are cheap enough. I wouldn't p*ss about with steering, it's what stops you from crashing Quote Link to comment Share on other sites More sharing options...
kevinr Posted September 27, 2008 Author Share Posted September 27, 2008 yeah, I figured as much..Paddocks do a nice heavy duty one, but the price is a little too much at the moment..too many damned anniversaries..lol oh well, looks like a replacement one on monday Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 27, 2008 Share Posted September 27, 2008 A temporary solution is to clamp the bugger to a length of angle iron and run a few welds along to keep it straight. It's a cheap way of strengthening a stock bar, or in this case keeping a banana'd one straight for a bit. Quote Link to comment Share on other sites More sharing options...
Phantom Posted September 28, 2008 Share Posted September 28, 2008 I’ve repaired / strengthened bent track rod bars but I believe any application of heat or weld to a steering component is technically a MOT fail - buy a new one! Lee Quote Link to comment Share on other sites More sharing options...
kevinr Posted September 29, 2008 Author Share Posted September 29, 2008 I’ve repaired / strengthened bent track rod bars but I believe any application of heat or weld to a steering component is technically a MOT fail - buy a new one!Lee I got a replacement today, it's second hand and in good condition (the guy I got it from is reputable) it will do as a temporary replacement until I can afford the heavy duty ones. Quote Link to comment Share on other sites More sharing options...
