rejo Posted September 29, 2008 Share Posted September 29, 2008 Amr 6429 its the green ecu it sits behind the glove box on a LHD not sure if its in the same place on a RHD. Anyway while rumaging yesterday for another cable I noticed that on the left side of the ecu is a red cab about 2.5 mm in diameter which is about 10 cms long and clipped onto the side of the box. If looking at the ecu the side with the stickers facing you then its the last cable on the left. Is this an antenna or something else as it looks like its just been cut off ..... only problem is I cant see the other end. Quote Link to comment Share on other sites More sharing options...
white90 Posted September 30, 2008 Share Posted September 30, 2008 10as alarm ecu Quote Link to comment Share on other sites More sharing options...
Fern Posted September 30, 2008 Share Posted September 30, 2008 Is this an antenna or something else as it looks like its just been cut off ..... only problem is I cant see the other end. yes. antenna. for keyfob. Quote Link to comment Share on other sites More sharing options...
rejo Posted September 30, 2008 Author Share Posted September 30, 2008 Antenna .... thought it might of been but wasn't sure. If I increase the length of the cable will it increase the range of the key fob ? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 30, 2008 Share Posted September 30, 2008 Antenna .... thought it might of been but wasn't sure. If I increase the length of the cable will it increase the range of the key fob ? No, radio antenna are tuned length. I wouldn't mess with it. Quote Link to comment Share on other sites More sharing options...
rejo Posted October 1, 2008 Author Share Posted October 1, 2008 Thanks to everyone for there replies. I'll leave it well alone then. It just looks like its been chopped off instead of having a cap or something over the end. Quote Link to comment Share on other sites More sharing options...
