MikeAK Posted October 1, 2008 Share Posted October 1, 2008 Hi, I need to do some repairs to the rear inner wings where they meet the wheel arches and the base of C pillars. Anyone know what thikness steel to use for making up repair pieces? Just want to know so I can obtain some steel before I pull off the outer wings and hack the bad stuff out to see the thickness of the original. I'm guessing about 1.2mm Its a 1989 3.5 Classic Thanks Mike Quote Link to comment Share on other sites More sharing options...
andyb Posted October 2, 2008 Share Posted October 2, 2008 Yes 1.2mm should do it. Don't be afraid to use something a little thicker than the original.....think of it as added time before rusting thru again Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 2, 2008 Share Posted October 2, 2008 I tend to use 2mm in most body patches, and most repair panels you buy are ~2mm, as said above it will last longer, and more forgiving when you are trying to weld it all together! Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted October 2, 2008 Share Posted October 2, 2008 Just been out and measured a piece of rear wing - 1.5mm thick on a 1990 RRC Quote Link to comment Share on other sites More sharing options...
Mark Posted October 2, 2008 Share Posted October 2, 2008 I tend to use 16 gage which is just over 1.5mm thick. Much more than that and it becores a real pain to bend and work with. hth Mark Quote Link to comment Share on other sites More sharing options...
MikeAK Posted October 2, 2008 Author Share Posted October 2, 2008 Hi again, Thanks for doing the measuring ThreeSheds, based on that and what the others say I'll go for 1.5 - 1.6 mm. Must have a walk over to maintenance dept this after noon and and casually mention I need some to weld up my RR. For some reason whenever I do that the steel fairy leaves some under my desk overnight Thanks Mike Quote Link to comment Share on other sites More sharing options...
