NicTheOrange90 Posted October 3, 2008 Share Posted October 3, 2008 A mate at work has a Td5 Disco, and he cannot open rear door, inspection by me revealed the central locking was not unlocking the rear door (all the rest OK). If you unlock the door from the inside, then close the door, and lock the car again the central locking makes the solenoid lock go down. I dont think its a door spring issue (dont know if TD5's have this yet). I have suggested he brings it to me and I test the solenoid, by anyone else had this problem? Quote Link to comment Share on other sites More sharing options...
K88 MUD Posted October 3, 2008 Share Posted October 3, 2008 Yeap.......now solenoid needed........ive changed a few. Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted October 3, 2008 Author Share Posted October 3, 2008 Thanks for that, so dont suppose its worth fitting a second hand one, Ill look them up on Microcat Quote Link to comment Share on other sites More sharing options...
john01473 Posted October 6, 2008 Share Posted October 6, 2008 Thanks for that, so dont suppose its worth fitting a second hand one, Ill look them up on Microcat I BOUGHT 2 SECOND HAND FROM EBAY FOR £7 + P+P I WAS QUOTED £60+ NEW. mine work perfect. Big John Quote Link to comment Share on other sites More sharing options...
stevepeely Posted October 7, 2008 Share Posted October 7, 2008 check that the handle out side is not sticking mine was and i had same fault wd40 did the trick Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 7, 2008 Share Posted October 7, 2008 Welcome Steve Peely to the best technical LR forum. Please update your profile to show where you are because it is important to others on the forum. Just a general area is fine. Quote Link to comment Share on other sites More sharing options...
DiscoMike Posted October 8, 2008 Share Posted October 8, 2008 I know you've probably checked but I had the same on my disco 1. my door could only be opened from the inside then the central locking would lock it again. I found it was just a child lock on the rear door. worth a check if not done so. Certainly save some money. Quote Link to comment Share on other sites More sharing options...
teabag Posted October 8, 2008 Share Posted October 8, 2008 As you are running a D2 then I believe the central locking actuator is combined with the lock unlike the D1. Thats progress for you. Quote Link to comment Share on other sites More sharing options...
