Fatboy Posted October 5, 2008 Share Posted October 5, 2008 Evening, My rebuild is progressing but I'm stumped with the clutch and at the point where it is needed I've got a large threaded, female fitting on the master cylinder: and a smaller one on the slave cylinder: Now, obviously I don't hard pipe all of the way and will run a flexi hose to the slave but the fittings are the same size on both ends (I've misplaced the hose at the moment). For a comparision, I got two fittings below which fit the two ends I have on the vehicle: Not only do they have different sized threads, they have different sized pipes in the ID! I've had a couple of variations from Craddocks but "blind" buying was getting a bit dear and we don't have a local independent that I know where I can explain my quandary over the counter. Can anybody help with part nos or a supplier or...?? Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted October 6, 2008 Share Posted October 6, 2008 Obviously a direct and informed answer on here will be best, but in terms of 'more local than 'addocks', if not exactly local, have you considered / had any experience of Davidson Mcmillan in Inverness? http://davidsonandmcmillan.co.uk/index.php Now you have created some pictures and text you could always try hawking an email round the more 'personal' suppliers. In that context, Beamends might give you information, but they don't do Mail Order, or The Landrover Orphanage have a good reputation in the Series 2 Club http://www.landroverorphanage.com/ P A Blanchards is another possibility. https://secure.pablanchard.co.uk/default.asp Otherwise it's a case of putting the adaptor (or complete Master Cylinder) in your pocket, with the Slave Cylinder in the other one, and trundling round Motor Factors in Aberdeen itself. Yes I know, that's easy for me to say, I'm a long way away :-) Good Luck. Quote Link to comment Share on other sites More sharing options...
zim Posted October 6, 2008 Share Posted October 6, 2008 i had a problem when i fitted servo brakes onto a series the one time. from what i recall i had to use the bigger fittings, with a small pipe ( 3/8 not 1/4). however i can't remember the size of fittings / pipework on a series clutch, i'm sure they normaly use 1/4" tubing though. here is an attachment of the parts page if it helps you. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 6, 2008 Share Posted October 6, 2008 There's a chap called Richard that owns the Land Rover Orphanage - he's the Series version of Ralph If you want any advice/help/parts for series motors, then give him a ring - 01249444450. Chippenham in Wiltshire, so down the road a bit from you . Les. Quote Link to comment Share on other sites More sharing options...
Fatboy Posted October 6, 2008 Author Share Posted October 6, 2008 Gents, That is all really helpful... I had some experiences with Davidson & McMillan a few years ago but maybe they have changed since then. I am over that way occasionally so may drop in if I have no luck on the alternatives provided.. The parts diagram lists a number of variations for each component in the clutch system so I'm now wondering if I am supposed to have a single bore all of the way through rather than a crossover somewhere.. I'll explore that option as well! When I gety a result, I'll let you know. (Can't do it this week because of work stuff ). Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted October 6, 2008 Share Posted October 6, 2008 The fitting in the master cylinder is a series 3 part(uses 1/4"od pipe & 7/16"UNF nuts), unscrew it and you will have the same 3/8"UNF thread in the master cylinder as in the slave and be back to s2/2a spec which is 3/16"od pipe and 3/8"unf tube nuts with a 3/8"unf male threaded hose. Quote Link to comment Share on other sites More sharing options...
bob86 Posted October 6, 2008 Share Posted October 6, 2008 I've got the same master and slave as you, like Phil says its a early slave and a later master cylinder. On mine I already had the larger series 3 flexi clutch hose so I got another adaptor and screwed it into the slave then used 1/4" od pipe. Quote Link to comment Share on other sites More sharing options...
TonkaIIa Posted October 14, 2008 Share Posted October 14, 2008 Donald, Hope this helps, but I think the part number for the Clutch Pipe Adaptor is 139082, this is the from the pipe to clutch master cylinder. Link below for the part Click here Click here Regards Gary Quote Link to comment Share on other sites More sharing options...
