CJRH Posted October 7, 2008 Share Posted October 7, 2008 Hi, I’ve got a Disco 200tdi engine to go in my series 2a, what bolts are used for the pressure plate to flywheel? I think they are m8, can I just use 8.8 strengh and what washers are used? Flat, star or split washers? Cheers, Chris Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 7, 2008 Share Posted October 7, 2008 No washers, but it wouldn't hurt if used them. They are M8 coarse thread, and about 15mm long. I suspect they would be hi-tensile, so 8.8 might be ok. Les. Quote Link to comment Share on other sites More sharing options...
CJRH Posted October 7, 2008 Author Share Posted October 7, 2008 Thanks Les, what stops the bolts from working loose? Chris Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 7, 2008 Share Posted October 7, 2008 I have just taken the clutch off a Series III diesel and there were spring washers under each bolt. I remember thinking that each bolt must be the same and have a washer to keep the balance as good as possible. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted October 7, 2008 Share Posted October 7, 2008 Spring washers on mine- no idea if standard or not but not caused any problems. Quote Link to comment Share on other sites More sharing options...
CJRH Posted October 7, 2008 Author Share Posted October 7, 2008 Thanks for the info, spring washers sound like a good idea! Cheers, Chris Quote Link to comment Share on other sites More sharing options...
dave88sw Posted October 9, 2008 Share Posted October 9, 2008 The torque setting is 25lbft fyi. This seemed very loose to me, so ive done mine to around 30, suppose this ought to be tight enough because they shouldnt work loose, but i wanted to be on the safe side. They are standard M8's and i reckon 8.8 ought to be ok, spring washers under mine too. Quote Link to comment Share on other sites More sharing options...
ciappi Posted October 10, 2008 Share Posted October 10, 2008 standard with spring washers and i would go with 10.8 tensille to be sure as i seen some types that are 8.8 and was cr-p Quote Link to comment Share on other sites More sharing options...
