McS Junior Posted January 22, 2006 Share Posted January 22, 2006 As you look into the ECU compartment (under the driver's seat) from the outside of the vehicle, there is a small yellow box to rear left. Am I correct in saying that this is the fuel pump relay? (R103) Cheer, Ross Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 As you look into the ECU compartment (under the driver's seat) from the outside of the vehicle, there is a small yellow box to rear left.Am I correct in saying that this is the fuel pump relay? (R103) Cheer, Ross Yes R103 is the fuel pump relay Quote Link to comment Share on other sites More sharing options...
McS Junior Posted January 22, 2006 Author Share Posted January 22, 2006 Yes R103 is the fuel pump relay hmmm, is that the little yellow box though? cant work it out from the Rave wiring diagrams... its got R6K8 written on it and is made by Siemens - presumably its a relay of some sort? Ross Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 Idents on the relay are most likely manufacturers numbers, have look in RAVE, in electrical libraries, '99 Td5 electrc lib,description/operation, fuel pump Td5, not having seen a Td5's elects close up I'm not sure of the relay colours. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 22, 2006 Share Posted January 22, 2006 In my copy of RAVE it says the fuel pump relay on a Td5 is C0730 and if you look up C0730 in the connector views in the electrical library it says it is in the fuse box in the facia (i.e. the one in front of the gear lever) From left to right the photo (p246 in the electrical library) shows Yellow relay Yellow relay Yellow relay Brown relay Green relay - the fuel pump relay Are you trying to find the fuel pump relay, or trying to figure out what the one under the seat does? Quote Link to comment Share on other sites More sharing options...
western Posted January 22, 2006 Share Posted January 22, 2006 Thats the same as my copy of RAVE. Quote Link to comment Share on other sites More sharing options...
McS Junior Posted January 22, 2006 Author Share Posted January 22, 2006 Thanks guys... I should mayve try and explain this a little better than I have! If you look on page 239 of the electrical libraries, the photo shows 3 yellow boxes. I dont have the left hand two, but its the right hand one thats knackered - what does it do and where do i get a part no. for it? Cheers, Ross Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 22, 2006 Share Posted January 22, 2006 Thanks guys... I should mayve try and explain this a little better than I have!If you look on page 239 of the electrical libraries, the photo shows 3 yellow boxes. I dont have the left hand two, but its the right hand one thats knackered - what does it do and where do i get a part no. for it? This is probably a dumb question, but if you don't know what it does how do you know it's knackered? i.e. if everything works what is the problem? OK, a bit of research in RAVE shows that it is page 100 you want, it is connector C0063 which is "Relay - Main". It appears several times in the electrical circuit diagrams if you do a search for "0063" and it also comes up on page 42 of the electrical library indicating it is something to do with feeding the aircon clutch and cooling fans. HTH Quote Link to comment Share on other sites More sharing options...
McS Junior Posted January 22, 2006 Author Share Posted January 22, 2006 This is probably a dumb question, but if you don't know what it does how do you know it's knackered? i.e. if everything works what is the problem? everything works but the relay itself is stuck - i'm getting driven nuts by the bloody thing buzzing!! cheers again for the help, still getting used to using rave... Ross Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 23, 2006 Share Posted January 23, 2006 OK, a bit of research in RAVE shows that it is page 100 you want, it is connector C0063 which is "Relay - Main". It appears several times in the electrical circuit diagrams if you do a search for "0063" and it also comes up on page 42 of the electrical library indicating it is something to do with feeding the aircon clutch and cooling fans.HTH Hmmm... aircon? my windey windows don't need relays!! Quote Link to comment Share on other sites More sharing options...
