indoken Posted October 25, 2008 Share Posted October 25, 2008 hi Anyone know the easiest way to test a thermostat as my engine stays cold all the time I think my thermostat may be stuck open. Many thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 25, 2008 Share Posted October 25, 2008 Take the stat out - you'll see if it's stuck open quite easily. There's a possibility that it's opening too soon as well, which is not so easy to detect. A new stat is very cheap and it might be worth just replacing it for the peace of mind. Les. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted October 25, 2008 Share Posted October 25, 2008 Put it in water and bring it to the boil. A 300Tdi thermostat should open at 88°C. They normally fail closed which is worse than failing open. Quote Link to comment Share on other sites More sharing options...
DrRob Posted October 25, 2008 Share Posted October 25, 2008 If the needle on the temp guage is not moving at all then suspect the temp sender perhaps??? If it does move but stays on the cold "side" then suspect thermostat. Rob Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 25, 2008 Share Posted October 25, 2008 I have never had much success with trying to boil thermostats and for the cost of a new one (genuine part is about a fiver, don't bother with anything else) by the time you drain the coolant and take it off you might as well just replace it anyway. Quote Link to comment Share on other sites More sharing options...
