stonie110 Posted October 31, 2008 Share Posted October 31, 2008 i am looking at buying 18inch wheels for my discovery 2. i want to fit all terrain tyres. what is the biggest size i can use? please any help would be great Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 31, 2008 Share Posted October 31, 2008 255/55R18 Grabber AT2 would be the standard equivalent, there is also a 255/60R18 version that is intended for the D3 but should also fit and would be a bit taller. I don't think you would find much else in 18in to fit, the AT2s are available in 2 wider sizes if you look here http://www.4site4x4.co.uk/tyre-details.aspx?id=6 but I have my doubts if they would fit on a D2 without surgery! Quote Link to comment Share on other sites More sharing options...
Orange Posted October 31, 2008 Share Posted October 31, 2008 Agree with Boggie! Anything wider than 255 will need the already large turning circle increased, or the arches widening and bigger offset wheels. Mine runs quite happily on it's General Grabber AT2s - 255/55R18. Quote Link to comment Share on other sites More sharing options...
McLandy Posted October 31, 2008 Share Posted October 31, 2008 17" Range Rover Sport/Disco 3 wheels with 265 70 17 and 245 75 17 bfg at's fit with no rubbing, run these on both my Td5's Quote Link to comment Share on other sites More sharing options...
stonie110 Posted June 17, 2009 Author Share Posted June 17, 2009 i ended up fitting 19 rangie wheels and 255/55/19 pirelli at tyres which worked well at tixover last weekend cheers Quote Link to comment Share on other sites More sharing options...
nicks90 Posted June 18, 2009 Share Posted June 18, 2009 fitting 18 or 19" wheels will mean you have lower profile tyres and a slightly more harsh ride though. i'd stick with 16", as its a nicer ride and you get a bigger choice of rubber! Quote Link to comment Share on other sites More sharing options...
stonie110 Posted June 20, 2009 Author Share Posted June 20, 2009 i ended up fitting 19 rangie wheels and 255/55/19 pirelli at tyres which worked well at tixover last weekend cheers does anyone know what tyre pressures i should be running? can't seem to find any info anywhere cheers Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 21, 2009 Share Posted June 21, 2009 The book says 28psi front 38psi rear for all factory tyre sizes. Quote Link to comment Share on other sites More sharing options...
stonie110 Posted June 21, 2009 Author Share Posted June 21, 2009 cheers. everwhere i look it tells me different pressures. i will try those. cheers again Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 21, 2009 Share Posted June 21, 2009 Those pressure come from the workshop manual so are the "proper" ones There is an addendum for post 03 vehicles saying 30psi for the front - don't know why. The reality is that it depends on all sorts of factors like speed, load, surface etc etc. We have low road speed limits here and rough gravel roads and because of that I run mine at about 25 front 30 rear at the moment to improve ride comfort, but that wouldn't be any good at motorway speeds. Quote Link to comment Share on other sites More sharing options...
