Rotor Posted November 4, 2008 Share Posted November 4, 2008 Anyone know why the head gasket on 300tdi`s has three holes for the waterways that go nowhere? I`m changing my gasket as it blown, some clown before has used tap water for cooling and it corroded the head where the three holes in the gasket are, the gasket holes dont seem to serve any obvious purpose or dose the head need water contacting it at these points? Ive attached a photo to show these points. Rgds Rotor Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 4, 2008 Share Posted November 4, 2008 I would imagine that it allows cooling water to get as close to the fire rings as possible in order to dissipate heat. You could do a forum test - block them up and let us know if your engine goes bang If Frida Turner reads this and makes me look like a complete numpty, then someone hacked my account and I didn't just post this Les. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 4, 2008 Share Posted November 4, 2008 Relax Les, you don't need Frida Turner to make you look a numpty Mo ...................................... running for cover Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 4, 2008 Share Posted November 4, 2008 I guess there was a 'need' supposed to be in there somewhere? Les. Quote Link to comment Share on other sites More sharing options...
Rotor Posted November 11, 2008 Author Share Posted November 11, 2008 Bump B) - Guess its a mystery then? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted November 11, 2008 Share Posted November 11, 2008 To save money in the factory they use the cut-outs to make other small gaskets (allegedly ) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 11, 2008 Share Posted November 11, 2008 Ignore that ^^^^^^^^^^^ Les Quote Link to comment Share on other sites More sharing options...
