sawcospoff Posted November 18, 2008 Share Posted November 18, 2008 Hi I have water in my footwell and my carpet is wet through. Are there any water pipes over the top of my gas pedal, or could it be a windscreen seal leak ? What do you think ? Please help. P reg P38 Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 18, 2008 Share Posted November 18, 2008 The priority is to discover if it's coolant or rainwater. Is your car LHD or RHD? Which footwell is wet, LH or RH? Quote Link to comment Share on other sites More sharing options...
sawcospoff Posted November 18, 2008 Author Share Posted November 18, 2008 The priority is to discover if it's coolant or rainwater.Is your car LHD or RHD? Which footwell is wet, LH or RH? It appears to be clear water so I would suspect rainwater, and it's in the drivers footwell under the gas pedal. It's a RHD by the way Preg P38 have I confused yoy with saying the gas pedal ? I can't spell accelerator. lol Quote Link to comment Share on other sites More sharing options...
orangemach5 Posted November 20, 2008 Share Posted November 20, 2008 It appears to be clear water so I would suspect rainwater, and it's in the drivers footwell under the gas pedal. It's a RHD by the way Preg P38 have I confused yoy with saying the gas pedal ? I can't spell accelerator. lol Would be worth checking the air-con condensate drains are clear, if not the heater box will pool with water and it will eventually end up on your carpets. Quote Link to comment Share on other sites More sharing options...
paintman Posted November 20, 2008 Share Posted November 20, 2008 http://www.rangerovers.net/newrremedies.htm#waterfoot Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted November 21, 2008 Share Posted November 21, 2008 It's a RHD by the way Preg P38 have I confused yoy with saying the gas pedal ? I can't spell accelerator. lol Yes :-) The others have picked up the technical bits. Cheers Quote Link to comment Share on other sites More sharing options...
