chassis 300tdi
Yes but,, you will have to have a Q plate as the chassis is not the correct type etc and will need an SVA perhaps !!!
Have a look at this document, very clear that if a "secondhand chassis is used vehicle must have ESVA and a Q plate
http://direct.gov.uk/en/Motoring/BuyingAnd...icle/DG_4022486
They are getting very hot on this and asking MOT testers to confirm chassis nrs, not from the VIN plate
Just forward of the spring hanger on the off-side I believe.
From what I read of the government website linked above a second-hand chassis from another vehicle would cause issues with the points system (being worth 5 against your score), whereas a new direct replacement 300tdi chassis will be fine as it's just a replacement part.
