TheRecklessEngineer Posted December 17, 2008 Share Posted December 17, 2008 Can anyone tell me how many RH and how many LH track rod ends I need to buy to replace them all on a S3? Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted December 17, 2008 Share Posted December 17, 2008 Moved from International to Series forum. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted December 17, 2008 Share Posted December 17, 2008 Can anyone tell me how many RH and how many LH track rod ends I need to buy to replace them all on a S3? Arm from box to relay - 1 of each Arm from relay to swivel - 1 of each Arm from swivel to swivel - 1 of each There are two patterns though, one threaded right up to the round cast bit and one that is threaded just short. The rods for the 1st type are threaded to the end, for the 2nd type the thread stops just short of the end. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 17, 2008 Author Share Posted December 17, 2008 Thank you very much. The vapour is slowly condensing... Quote Link to comment Share on other sites More sharing options...
Snagger Posted December 17, 2008 Share Posted December 17, 2008 Three of each (one of each for the track rod, the drag link and longitudinal link). The trick is to make sure the threads are right - most had Imperial threads, but the very late SIIIs have metric. Quote Link to comment Share on other sites More sharing options...
rtbarton Posted December 17, 2008 Share Posted December 17, 2008 Three of each (one of each for the track rod, the drag link and longitudinal link). The trick is to make sure the threads are right - most had Imperial threads, but the very late SIIIs have metric. Which threads? The ones in the rods or the ones for the securing nyloc nuts? TRE's are usually supplied with nuts anyway. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted December 17, 2008 Share Posted December 17, 2008 The TRE to rod thread is the same 11/16"UNS thread on all series rods but with the variation in thread length dependant on age and obviously LH & RH threads. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted December 27, 2008 Author Share Posted December 27, 2008 Cheers chaps - full set of new TREs on the shelf...just got to fit the buggers, and all the bodywork, and the engine, and brakes, electrix etc... Quote Link to comment Share on other sites More sharing options...
