Stu2985 Posted December 21, 2008 Share Posted December 21, 2008 Whilst poking around under my EGR removed 1996 300tdi Auto with early engine management system and electronic fuel pump I noticed a small hole that looks like it should connected or be blanked off in the pipe that runs between by AFM and the turbo it wasnt connected to anything or blanked off just open - does that mean its been sucking in unfiltered carp as that pipe was full of crud. I have blanked it off for now but should it go somewhere? Disco feels as though its pulling better with it plugged Quote Link to comment Share on other sites More sharing options...
bango690 Posted December 21, 2008 Share Posted December 21, 2008 Whilst poking around under my EGR removed 1996 300tdi Auto with early engine management system and electronic fuel pump I noticed a small hole that looks like it should connected or be blanked off in the pipe that runs between by AFM and the turboit wasnt connected to anything or blanked off just open - does that mean its been sucking in unfiltered carp as that pipe was full of crud. I have blanked it off for now but should it go somewhere? Disco feels as though its pulling better with it plugged crank case breather? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted December 21, 2008 Share Posted December 21, 2008 I reckon it's for NOS Quote Link to comment Share on other sites More sharing options...
pinny Posted December 21, 2008 Share Posted December 21, 2008 Whilst poking around under my EGR removed 1996 300tdi Auto with early engine management system and electronic fuel pump I noticed a small hole that looks like it should connected or be blanked off in the pipe that runs between by AFM and the turboit wasnt connected to anything or blanked off just open - does that mean its been sucking in unfiltered carp as that pipe was full of crud. I have blanked it off for now but should it go somewhere? Disco feels as though its pulling better with it plugged i would say crankcase breather so where does your breather go has it fallen off or into a oil tank Quote Link to comment Share on other sites More sharing options...
Stu2985 Posted December 21, 2008 Author Share Posted December 21, 2008 Whilst poking around under my EGR removed 1996 300tdi Auto with early engine management system and electronic fuel pump I noticed a small hole that looks like it should connected or be blanked off in the pipe that runs between by AFM and the turboit wasnt connected to anything or blanked off just open - does that mean its been sucking in unfiltered carp as that pipe was full of crud. I have blanked it off for now but should it go somewhere? Disco feels as though its pulling better with it plugged thanx for the replies - The disco has extended breathers fitted i think 5 in total inc axles - would one be fitted to the crank case ? where should i be looking on the engine to find the other end where this pipe should go sorry still learning my way around discos Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted December 21, 2008 Share Posted December 21, 2008 Hi there. I would not have thought that the axles would connect to the crankcase, rather just vent to atmosphere. The hole in the piping that goes to the input of the turbo is for the crankcase breather pipe. It should have an elbow fitting that connects to tubing, which goes around the rear of the cylinder head and connects to the flame oil trap (from memory). The pipe in the picture does not look familiar - was it just lying around in the engine bay ? Cheers Quote Link to comment Share on other sites More sharing options...
Stu2985 Posted December 21, 2008 Author Share Posted December 21, 2008 Hi there.I would not have thought that teh axles would connect to the crankcase, rather just vent to atmosphere. The hole in the piping that gies to the input of the turbo is for the crankcase breather pipe. It should have an elbow fitting that connects to tubing, which goes around the rear of the cylinder head and connects to the flame oil trap (from memory). The pipe in the picture does not look familiar - was it just lying around in the engine bay ? Cheers thanx for the replies found the crank case end dangling down behind the back of the engine - odd how it came undone but i did haev some work on teh turbo manifold carried out few weeks ago maybe they forgot to reconnect it does the black crankcase filter need changing mine looks awfully oily around it ? Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted December 21, 2008 Share Posted December 21, 2008 thanx for the repliesfound the crank case end dangling down behind the back of the engine - odd how it came undone but i did haev some work on teh turbo manifold carried out few weeks ago maybe they forgot to reconnect it does the black crankcase filter need changing mine looks awfully oily around it ? Your welcome. There should be no need to replace as there is not much too it. The procedure is to remove and wash through with paraffin or diesel to clean. It's more of a trap than a filter. Although the stub that fits in the rocker cover has an O ring, on mine it was pretty ineffective so I made up a gasket using thin cardboard (cereal box type cardboard) where it mates against the rover cover, as they tend to leak/fume at the joint. Or you could use a thin smear of gasket sealant, personally I prefer cardboard as its easier to remove/refit in the future. Enjoy your tinkering. Best regards Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted December 21, 2008 Share Posted December 21, 2008 Ignore my comment about not recognising the pipe in the picture . Having zoomed in on it I can see it's the input duct from airflow meter to turbo and the arrow is pointing at the hole. Doooh! I thought it was a piece of small pipe that you found under the bonnet. Me thinks my glasses need upgrading Quote Link to comment Share on other sites More sharing options...
muddy Posted December 22, 2008 Share Posted December 22, 2008 I thought the NOS went in post turbo john? Quote Link to comment Share on other sites More sharing options...
