Ibex94 Posted December 30, 2008 Share Posted December 30, 2008 Am in process of checking over the steering box for my truck before fitting it. There is a small amount of backlash in the input shaft, how much backlash should I expect, what is acceptable and can it be adjusted out? You help and advice gratefully awaited. Ta Rob Quote Link to comment Share on other sites More sharing options...
western Posted December 31, 2008 Share Posted December 31, 2008 large nut with a allen bolt in the centre is the normal backlash adjustment point, minimal play would be OK. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted December 31, 2008 Share Posted December 31, 2008 Am in process of checking over the steering box for my truck before fitting it. There is a small amount of backlash in the input shaft, how much backlash should I expect, what is acceptable and can it be adjusted out?You help and advice gratefully awaited. Ta Rob Check on google images with " Steering Box adjustments" and you will get loads of advice. I had that serious play on mine. Heck of a job but got it done finally!! I have the link below!!!! Best Regards http://images.google.no/imgres?imgurl=http...l%3Dno%26sa%3DG Quote Link to comment Share on other sites More sharing options...
