Andrew Chua Posted January 1, 2009 Share Posted January 1, 2009 Hi all, I've finished re fitting one side of my landie using the factory regulator. aka i did a manual to powered window conversion. looking good so far. After peeling back the 'vinyl layer' behind the door card (what's it called?), it has this black sticky stuff which holds it to the door. Now as I think the sheet is in a terrible condition, I would have to replace it and then look for the sticky black stuff to stick it. 1. What's the piece of clear vinyl layer know as? do i really need it? 2. What's the black stuff known as? where can i get it? Thanks for the help!! Happier New Year Andrew Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted January 1, 2009 Share Posted January 1, 2009 get a bit ot tarpaulin and some ducktape! It acts as a moister barrier but in a Land rover that seems a little laughable, I didn't bother whan I swapped doors Quote Link to comment Share on other sites More sharing options...
western Posted January 1, 2009 Share Posted January 1, 2009 it's a moisture barrier as suggested above, the black stuff is just a sticky mastic to secure the plastic sheet in place, it's meant to keep water away from the door trim panel. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted January 3, 2009 Author Share Posted January 3, 2009 moisture? it seems to be keeping in the moisture. got rust all over the lower edge of the door when i removed the black stuff. I think I can live without it. Thanks guys!! Quote Link to comment Share on other sites More sharing options...
roybatty666 Posted January 3, 2009 Share Posted January 3, 2009 moisture? it seems to be keeping in the moisture. got rust all over the lower edge of the door when i removed the black stuff.I think I can live without it. Thanks guys!! That's a Landrover feature, soon the bottoms of the doors will rust out and let all the water out for you Quote Link to comment Share on other sites More sharing options...
