Tall Paul Posted January 12, 2009 Share Posted January 12, 2009 Hello there I have recently bought a T reg TD5, well aware that the sunroof has a leak. NOt quite sure which one it is. Took it to local stratstone they said £250 to strip head lining and water test the roof. I get a call saying they found the glass roof had been bonded to the rubber seal, then forced open tearing the rubber seal. Then quoted me £700 to get a new sunroof and fit on top of the £250. Is that the normal rate ?? anybody had similar problem ?? Robbing b********ds any body managed to fix this problem a lot cheaper ?? manual sunroofs bog standard ! Many thanks in advance ! Tall Paul Quote Link to comment Share on other sites More sharing options...
teabag Posted January 13, 2009 Share Posted January 13, 2009 That will be right Robbing b********ds, what do main dealers charge now, last time I went to one for a service was 6 years ago then it was £58ph. You can buy the rubber seal on ebay for around £22 for two. Just enter Discovery sunroof, it's an easy diy job to fit. Quote Link to comment Share on other sites More sharing options...
task Posted January 13, 2009 Share Posted January 13, 2009 Is there a difference between Discovery 1 300 and Disco II sunroof? Quote Link to comment Share on other sites More sharing options...
teabag Posted January 13, 2009 Share Posted January 13, 2009 No difference in sunroofs. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted January 13, 2009 Share Posted January 13, 2009 Rubber seal for the sliding sunroofs, part# EEQ500010, http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...em=330292284847 (or google for the part#). Quote Link to comment Share on other sites More sharing options...
M&S Posted January 13, 2009 Share Posted January 13, 2009 WOW! I wouldn't have thought a new sunroof would have been that expensive even at the stealers. But as said, you don't need the full sunroof, just the seal. I'd be bringing that fact up with them and see there reply. Maybe threaten with trading standards (they are obviously selling you a part that isn't needed)? You might be able to get the new seal fitted for no extra cost, considering they have already stripped the rooflining etc. You've paid them to remove the lining anyway, you may as well have them fit the seal otherwise you'll be having to finish the job yourself. Quote Link to comment Share on other sites More sharing options...
