Badger90 Posted January 15, 2009 Share Posted January 15, 2009 hi chaps. is there any diffence in the 200Tdi and 300Tdi fuel pumps? i got told last night that if you shove a 300Tdi fuel pump on 200Tdi engine it bumps the power up abit more. but i thought the pumps where the same? cheers sam Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2009 Share Posted January 15, 2009 if you mean the fuel lift pump Yes they are different. doubt changing a lift pump would give any power increase, but the injection pump might. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted January 15, 2009 Author Share Posted January 15, 2009 if you mean the fuel lift pump Yes they are different. doubt changing a lift pump would give any power increase, but the injection pump might. no sorry i ment the injector pump Quote Link to comment Share on other sites More sharing options...
western Posted January 15, 2009 Share Posted January 15, 2009 the 300 injection pump will fit but some have the EDC electrics in a box over the fuel shtoff solenoid, this edc stuff can be removed IIRC. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted January 15, 2009 Author Share Posted January 15, 2009 the 300 injection pump will fit but some have the EDC electrics in a box over the fuel shtoff solenoid, this edc stuff can be removed IIRC. ok. is there any differnce in how much fuel they shove into the injectors? Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted January 17, 2009 Share Posted January 17, 2009 ok. is there any differnce in how much fuel they shove into the injectors? As the quoted torque and power figures are the same, I rather doubt it. If you want more power from your 200, tweak the injector pump you have fitted. See post in the Tech Forum. Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted January 17, 2009 Share Posted January 17, 2009 wolf 300tdi inj pump on a 200tdi makes good power with less smoke Quote Link to comment Share on other sites More sharing options...
