DiscoStu Posted January 17, 2009 Share Posted January 17, 2009 I'm sure this has been asked before but I cant seem to locate anything via "Search", so apologies in advance. Is there a program I can get hold of, similar to the old microfiche style machines, which would enable me to see parts, numbers, diagrams etc? Specifially I'm after 1994 300tdi. The speed some of you guys come back with parts numbers I'm guessing there must be something? Stu. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 17, 2009 Share Posted January 17, 2009 http://www.brownchurch.co.uk/download.html Engine overhaul manual is in the list, which is what I have. I use EPC for part numbers though. Les. Quote Link to comment Share on other sites More sharing options...
David Sparkes Posted January 17, 2009 Share Posted January 17, 2009 Search under EPC for the older version, or Microcat for the later version. Obviously the EPC database is not maintained, but if you choose to use it you at least get a starting point for the Part Number, even if you then find it has been superseeded. As you read the threads you will see that which you choose is more personal preference than anything, although if you want prices, current or recent, then you need Microcat. HTH Quote Link to comment Share on other sites More sharing options...
v8bertha Posted January 17, 2009 Share Posted January 17, 2009 What you want is MicroCat... Available from The Green Oval web site HTH Dan Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted January 17, 2009 Author Share Posted January 17, 2009 Thanks guys. Stu. Quote Link to comment Share on other sites More sharing options...
