rocky Posted January 27, 2009 Share Posted January 27, 2009 Hi, Do the td5's have air suspension, and if so can the be converted to springs. Regards, Rocky Quote Link to comment Share on other sites More sharing options...
Les Henson Posted January 27, 2009 Share Posted January 27, 2009 Yes they can. Air suspension faults are quite common, so a 'kit' to convert it to coil suspension is relatively cheap. http://forums.lr4x4.com/index.php?showtopic=25538 Les. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 27, 2009 Share Posted January 27, 2009 Not all S2 Discoverys have air springs though, 5 seat vehicles can be either. Mine has lovely coils still working faultlessly, seven years later it still doesn't have a saggy @r5e in the morning Quote Link to comment Share on other sites More sharing options...
rocky Posted January 27, 2009 Author Share Posted January 27, 2009 thanks for the replies, also I believe that some 1999's and 2004's have difflock, please correct me if I'm wrong. rocky Quote Link to comment Share on other sites More sharing options...
extreme spain Posted January 27, 2009 Share Posted January 27, 2009 The parts that you will need to do the air spring conversion are: ANR2938 x2 spring isolator RYG101360 x4 Bolts ANR 3578 x2 Seats You can add springs of your choice or, all round change for a lift. I am currently converting a Td5 for overland trips. Quote Link to comment Share on other sites More sharing options...
wobbly bob Posted January 27, 2009 Share Posted January 27, 2009 thanks for the replies, also I believe that some 1999's and 2004's have difflock, please correct me if I'm wrong. rocky I beleive that some early models can have difflock re activated as they have the workings in the transfer box and the wiring in place behind the dash etc, but the procedure to re-activate is a bit of a job. Not really worth it in my opinion as the d2 is extremely capable as it is with its t/c. Check out discovery2.co.uk this guy knows his landy and shows the procedure and what is involved. I would only do it if you intend doing some serious off roading (but then I would buy a Defender instead). Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 27, 2009 Share Posted January 27, 2009 I agree, which is why I have a Defender Quote Link to comment Share on other sites More sharing options...
Wingnut Posted January 28, 2009 Share Posted January 28, 2009 I beleive that some early models can have difflock re activated as they have the workings in the transfer box and the wiring in place behind the dash etc, but the procedure to re-activate is a bit of a job. Not really worth it in my opinion as the d2 is extremely capable as it is with its t/c. Check out discovery2.co.uk this guy knows his landy and shows the procedure and what is involved. I would only do it if you intend doing some serious off roading (but then I would buy a Defender instead). I agree that the D2 is a very capable vehicle with Traction Control but it is even better with the centre diff lock operational. The traction control hardly kicks in once the diff lock is engaged. Don't be too dismisive about the D2's suitability for "serious offroading" - it is veritable Wolf In Sheep's Clothing. Lose some of the interior weight and put some decent bumpers on and away you go. It is also very comfortable and the heater works !!! Regards, Peter. Quote Link to comment Share on other sites More sharing options...
wobbly bob Posted January 29, 2009 Share Posted January 29, 2009 I agree that the D2 is a very capable vehicle with Traction Control but it is even better with the centre diff lock operational. The traction control hardly kicks in once the diff lock is engaged.Don't be too dismisive about the D2's suitability for "serious offroading" - it is veritable Wolf In Sheep's Clothing. Lose some of the interior weight and put some decent bumpers on and away you go. It is also very comfortable and the heater works !!! Regards, Peter. Hey, I agree. The D2 is superb off road, been there done that and still doing it. Departure angle is obviously an issue even with decent bumpers for serious work, it can make a good ground anchor though! Regarding the weight issue, I like my pies ok! you sound just like the wife. Regarding the comfort, you sound like a wanna be rambler. Regarding the heater, I have a wooly hat incase I ever get another Defender. Cheers, Jon. Quote Link to comment Share on other sites More sharing options...
MrDiagnostic Posted January 30, 2009 Share Posted January 30, 2009 Just done mine very easy,about £80 for parts,i turned air suspension light off with my rovacom,or you could just remove bulb and disconnect compressor.any more info pm me...........Cheers Quote Link to comment Share on other sites More sharing options...
