Hamish Grundy Posted January 29, 2009 Share Posted January 29, 2009 hi, the rear crank seal has gone on my 300tdi, normaly i wouldnt worry and just pull the engine out and do it, but i have never split an auto, i have heard of problems when reassembly, inparticular lining the pump drive up in the torque converter, is there an easy way to do it? Quote Link to comment Share on other sites More sharing options...
nibbles Posted January 30, 2009 Share Posted January 30, 2009 hamish give me a ring over the weekend and i'll tell you the easy way. as i have done it lots of times with the racer and i've got it down to an art as i can get the box out on the floor in 30 mins. my mobile is 07917801590. adrian. Quote Link to comment Share on other sites More sharing options...
PEASEY Posted January 30, 2009 Share Posted January 30, 2009 Could you post up how you get on as I have got to do mine as its on its way out and want to sort it before it just lets go,thanks peasey. Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted February 1, 2009 Author Share Posted February 1, 2009 hamish give me a ring over the weekend and i'll tell you the easy way. as i have done it lots of times with the racer and i've got it down to an art as i can get the box out on the floor in 30 mins. my mobile is 07917801590.adrian. ok cheers mate, doubt il get time to ring u 2day sorry, il have to take the engine out cos i havnt got the room to move the autobox back, from what i can see in the book i just have to line it up and apply slight pressure to the engine whilst turning it over with a socket, it just worries me that the only way il know that its ok is when its all back it, and if i have cracked the gear il have to pull it appart again. i think i may just have to bite the bullet and do it, saying that... it will probly still be that same at the next event ha Quote Link to comment Share on other sites More sharing options...
nibbles Posted February 2, 2009 Share Posted February 2, 2009 the thing to do mate is to undo the torque convertor from the engine, i.e leave it attached to the box. when you do this just hold it in place with a couple of cable ties. then you don't have to worry about the seal on the gearbox pump. then you can take the engine out, change the seal, then but it back in and re-attach the torque convertor, i is only 4 bolts on a standard box which isn't to bad compared to my racer which is 8 bolts. just make sure when you do them back up you put some lock tite on the as you don't want them to come undone as it will bend the flexi plate if they come loose. any problems then give me a ring you have my number. Quote Link to comment Share on other sites More sharing options...
clbarclay Posted February 2, 2009 Share Posted February 2, 2009 All the torque converter bell housings I've seen have an removable plate so that the flex plate can be unbolted from either the torque convetor (in the case of the LR autos) or the flywheel while the gearbox and engine are bolted together. If the torque covertor does come off the gearbox then you just place it back on, apply ligth presure while turning it and turning. As each set of splines lines up the torque convertor moves back a bit further. With the gearbox and engine back together just turn the flywheel untill a hole in the flex plate is accesible and spin the torque covertor round to line up the holes. Quote Link to comment Share on other sites More sharing options...
Hamish Grundy Posted February 2, 2009 Author Share Posted February 2, 2009 All the torque converter bell housings I've seen have an removable plate so that the flex plate can be unbolted from either the torque convetor (in the case of the LR autos) or the flywheel while the gearbox and engine are bolted together.If the torque covertor does come off the gearbox then you just place it back on, apply ligth presure while turning it and turning. As each set of splines lines up the torque convertor moves back a bit further. With the gearbox and engine back together just turn the flywheel untill a hole in the flex plate is accesible and spin the torque covertor round to line up the holes. il have to have a look, thanks to you both for your help, does anyone know if the 300tdi has a removable plate on it? cheers. Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted February 3, 2009 Share Posted February 3, 2009 On mine I had to work through the starter motor hole, it has a cut out to allow a socket to be used on the bolts. There is an inspection cover on the bottom of the bell housing but IIRC it doesn't allow access to the bolts. Pete. Quote Link to comment Share on other sites More sharing options...
nibbles Posted February 3, 2009 Share Posted February 3, 2009 there is a removable plate, but you have to use spanners as you can't get a socket on them. i would do this as it means you can leave the starter moter in place. it just takes a bit longer to undo the bolts this way thats all. Quote Link to comment Share on other sites More sharing options...
bango690 Posted February 3, 2009 Share Posted February 3, 2009 i have had to split a auto box and did monage to get a socket on it! (after a bit of swearing) Quote Link to comment Share on other sites More sharing options...
