simonr Posted February 4, 2009 Share Posted February 4, 2009 Sorry Ralph! For a current project, I have an anti roll bar bush which I thought came from a Disco 2 rear. My supplier identified this as RBX101700 - but now it's turned up - it's rather different! The dirty one is the one I want - the clean one what they sent. The bore of the dirty one is about 32mm whereas the clean one is 30ish - and obviously the clean one is much wider 66mm instead of 46mm. Any idea what the dirty bush might be from or what it's part number is? Also, I wanted a mounting strap for a defender - which is the same width as the dirty bush above. They sent me this: Which I believe is a 90 rear NTC6776. What I was hoping for was a 110 rear with four bolt holes rather than two as above. What's it for? Essentially I'm fitting an anti roll bar which is 32mm diameter to the rear of my 110. Difference it - it's un-lockable. I made one by drilling out standard bushes (not ideal) and it works brilliantly. It allows for up to 16" of movement (compared to 9" on a standard bar) by having much longer knuckles and doesn't affect ground clearance. The 32mm bar is very stiff and gives good handling even with a lot of weight high up - but can obviously be unlocked to give no restriction. Should be good for expedition trucks with Jerry cans on the roof as well as those with flexy suspension just wishing to drive safely on the road. Any help with the actual part numbers would be much appreciated! Si Quote Link to comment Share on other sites More sharing options...
Les Henson Posted February 4, 2009 Share Posted February 4, 2009 There are only two rear arb bushes listed , Si - 90" (except 50 LE) = NTC 7394. Except 90" - NRC 5674. The 4-hole bracket is square in profile - 110" = NRC 5724, same number for a 130", then handed ones for a 90 - LH - ANR4547, and RH -ANR 4546. All S1 and S2 disco's are 2-bolt bracket. Les. Quote Link to comment Share on other sites More sharing options...
western Posted February 4, 2009 Share Posted February 4, 2009 110 rear bush strap in my 110 1987 on parts book is identified as 592773 & the bush for a 110 is NRC5674 Quote Link to comment Share on other sites More sharing options...
simonr Posted February 4, 2009 Author Share Posted February 4, 2009 Thanks chaps - any ideas on the bushes? Si Quote Link to comment Share on other sites More sharing options...
western Posted February 5, 2009 Share Posted February 5, 2009 it might be a Freelander bush RBX101240 or RBX000010 which look similar as far as I can tell from the microcat diagram. Quote Link to comment Share on other sites More sharing options...
simonr Posted February 6, 2009 Author Share Posted February 6, 2009 Definitely Disco - probably D2, but could be D3. Si Quote Link to comment Share on other sites More sharing options...
western Posted February 6, 2009 Share Posted February 6, 2009 D2 rear bushes are RBX101700 on air suspension rear or RBX101710 on coil spring rear I haven't got any D3 info. Quote Link to comment Share on other sites More sharing options...
simonr Posted February 6, 2009 Author Share Posted February 6, 2009 D2 rear bushes are RBX101700 on air suspension rear or RBX101710 on coil spring rear I haven't got any D3 info. Thanks Ralph - I'll order some and see! Si Quote Link to comment Share on other sites More sharing options...
