teamplayer Posted February 12, 2009 Share Posted February 12, 2009 Hi all, Having replaced the headgasket (3 times) and the temp sender, voltage stabiliser, thermostat (82 degrees) and rad cap (10 psi) When the motor has warmed up I find that the temperature reading is in the middle of the red but remains constant there. However, when I stop and lift the bonnet to check if it's boiling up or not the radiator is hot at the top but cold at the bottom. The heater hoses are quite hot and the heater is blowing reasonably warm air. There is some overspill from the haeder tank but I'm not sure if the motor is finding it's own level. I have trawled through the tech section and have seen some other similar problems but nothing that quite pin-points mine. Anbody any thoughts on this Regards Mike Stockport ps sorry about the spelling of "radiator" in the title but I can't edit it Quote Link to comment Share on other sites More sharing options...
rtbarton Posted February 12, 2009 Share Posted February 12, 2009 Have you got an accurate thermometer you can dip in the header tank to get a proper reading? You'd expect the rad to be hot at the top and cold at the bottom, especially in this weather, that's its job. You could try reverse flushing it, but I would expect boiling if it was significantly blocked. Quote Link to comment Share on other sites More sharing options...
teamplayer Posted February 13, 2009 Author Share Posted February 13, 2009 I think I have sorted out the problem. I removed the stat today and it runs just below the "N" with the rad muffler half-open. I will replace the stat with a 72 degree one and that should sort it out. yours relieved, Mike Stockport Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted February 14, 2009 Share Posted February 14, 2009 In this weather I'd have expected the temperature gauge to barely move if I was running a diesel without a thermostat. Quote Link to comment Share on other sites More sharing options...
Phil Hancock Posted February 14, 2009 Share Posted February 14, 2009 Rads most likely blocked or the fins are degraded. Quote Link to comment Share on other sites More sharing options...
