renault4 Posted February 14, 2009 Share Posted February 14, 2009 I have a 1991 def. 90 Tdi with a leaking steering box. It is a six bolt jobby but I have been told that originally it would have been a 4 bolt. I have noticed that 4 bolters are more thick on the ground that 6-ers, my question is, what should be there and can I replace my 6-er with a 4-er? Quote Link to comment Share on other sites More sharing options...
western Posted February 14, 2009 Share Posted February 14, 2009 depends on what LR fitted from new, my '89 has a 6 bolt Gemmer PAS box, had no problems with it. might have to change hoses/pipes if end fitting threads are different Quote Link to comment Share on other sites More sharing options...
JST Posted February 15, 2009 Share Posted February 15, 2009 if you change the bolt no on the box you will probably need to change the pipes too, some unions are different. i believe 4 bolt are the strongest LR ones anyway Quote Link to comment Share on other sites More sharing options...
Briarston Posted February 15, 2009 Share Posted February 15, 2009 if you change the bolt no on the box you will probably need to change the pipes too, some unions are different.i believe 4 bolt are the strongest LR ones anyway Hello I have an ex-Disco 4 bolt box if you want one. Open to offers! Quote Link to comment Share on other sites More sharing options...
