Bobtail-Jay Posted February 14, 2009 Share Posted February 14, 2009 Hi all Got a CB to put in my bobtail And would like some ideas on where to put it Some pics would be niice?? And In cab winch switchs Where abouts ? And what switches , ive heard just normal window switches are good to use. Any info please tell me? Jay. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 14, 2009 Share Posted February 14, 2009 Couple of pictures in this thread: link Check out mud for switches ..... Link to company and some pics of switches in this thread: link Quote Link to comment Share on other sites More sharing options...
unclebill1 Posted February 14, 2009 Share Posted February 14, 2009 Hi all Got a CB to put in my bobtail And would like some ideas on where to put it Some pics would be niice?? And In cab winch switchs Where abouts ? And what switches , ive heard just normal window switches are good to use. Any info please tell me? Winch switches, I just used the rear window switches in the central console, cos I aint got no rear windows and the central console is standard for two and four door Discos. CB, even lazier, two coat hooks and hangs down the passenger side, that way I can change it from car to car. Bill Quote Link to comment Share on other sites More sharing options...
nige90 Posted February 15, 2009 Share Posted February 15, 2009 Got one of Mudstuffs centre console in mine with some Carling switches. Very pleased with it too. Linky Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 15, 2009 Share Posted February 15, 2009 Where to put them: Wherever you find is best for you, it's only wires, they can go anywhere. I vote for up high to avoid water & crud. Which switches to use: Whatever switches you most like the look/feel of. Momentary (often described as "(on)/off/(on)" action) are the usual choice but that does give you a whole load of different types to choose from. Quote Link to comment Share on other sites More sharing options...
JONNIGEE Posted February 16, 2009 Share Posted February 16, 2009 Hi all Got a CB to put in my bobtail And would like some ideas on where to put it Some pics would be niice?? And In cab winch switchs Where abouts ? And what switches , ive heard just normal window switches are good to use. Any info please tell me? Jay. Got my CB in the bay where the sunroof control panel is (was). My landy aint got a s/rf so it's fits snug without affecting anything. Got a 3ft spring base aerial on back right hand corner above top rear door hinge. Quote Link to comment Share on other sites More sharing options...
Fern Posted February 17, 2009 Share Posted February 17, 2009 Got my CB in the bay where the sunroof control panel is (was). My landy aint got a s/rf so it's fits snug without affecting anything. Got a 3ft spring base aerial on back right hand corner above top rear door hinge. I like the idea and I was also planing to put CB there. Please, do some more photos. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 17, 2009 Share Posted February 17, 2009 You can see how to do it here: http://www.discoweb.org/cbinstall/index.htm Although you'll need to do some more cutting for the CB to get in since the one you have (or will buy) it's most likely to be bigger (wider) than the one used that link. Quote Link to comment Share on other sites More sharing options...
Fern Posted February 17, 2009 Share Posted February 17, 2009 You can see how to do it here: http://www.discoweb.org/cbinstall/index.htmAlthough you'll need to do some more cutting for the CB to get in since the one you have (or will buy) it's most likely to be bigger (wider) than the one used that link. Thank you for the pics. The bad thing is that I have a sunroof:) Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 17, 2009 Share Posted February 17, 2009 You can see how to do it here: http://www.discoweb.org/cbinstall/index.htm That write up is missing a picture of the finished thing! Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 17, 2009 Share Posted February 17, 2009 The bad thing is that I have a sunroof:) Then you won't be able able to use the space behind the switches. You can mount it further back (pics also from discoweb): Anderzander, all you have to do is look at the 3rd pic and imagine the console back in its place and also imagine a mic on a side with its curly wire hanging. That's all there is to it. The CB is in its final position relative to the console, half in, half out - in case you didn't figure this out by yourself. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted February 17, 2009 Share Posted February 17, 2009 thanks cipx2 - I wasn't sure if that was as far in as it went. Quote Link to comment Share on other sites More sharing options...
