robhybrid Posted February 20, 2006 Share Posted February 20, 2006 I am after wiring diagrams for the 3.5 v8. I am after the diagrams that cover everything that is attatched to the engine/ecu(ecm). on a kreg example. I am ideally after diagrams for the hot wire version but would be interested in seeing the diagrams for the flap type too. My rave discs have good diagrams for the defender but only a fault finding section for the rrclasic and discovery1 I have most of the wiring loom and ecm for a 1993 model but the engine I intend on fitting it to is a 1991 model. Quote Link to comment Share on other sites More sharing options...
Tomcat Nev Posted February 20, 2006 Share Posted February 20, 2006 If you join the V8 owners forum all of the wiring diagrams are on a sticky plus loads of help if you need it. Try: http://www.v-8.org.uk/forum/topic.asp?TOPIC_ID=3046 Cheers Nev Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted February 21, 2006 Share Posted February 21, 2006 14.38 in your Range Rover Hayneous manual has the wiring diagram for the whole Hotwire system - that should cover pretty much everything. Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 21, 2006 Share Posted February 21, 2006 I've tried to unpick the various hotwire diagrams into an easy hook-up diagram for MogLite. I'll post up what I've done tonight, as it is on the PC at home. Quote Link to comment Share on other sites More sharing options...
MogLite Posted February 21, 2006 Share Posted February 21, 2006 I've tried to unpick the various hotwire diagrams into an easy hook-up diagram for MogLite.I'll post up what I've done tonight, as it is on the PC at home. I'm not sure if this is finished, but it debuged a lot of the mystery of the hotwire loom for me. If its of any use, or you want additions/changes let me know. I'll be at ECU wiring in a couple of weeks Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 21, 2006 Share Posted February 21, 2006 If you need the 3.9 EFI test sheets and (i think, i can't remember... but maybe the wiring diagram too) I scanned it all in ages ago and Matt Reeve hosted it on his rangie.com site. I've definately got the 3.9 workshop manual here (in paper form) if anyone needs any info out of it. Quote Link to comment Share on other sites More sharing options...
