Madcowz Posted March 20, 2009 Author Share Posted March 20, 2009 thanks guys, Raided my Clio spare light bulb set for one and it works. Only trouble is that the number plate lamp and shroud don't seem to shine on the number plate much. The way it is attached to the bracket means that the light is either shining up or down rather than right at the plate. I took the whole lamp off to see if it could be put back on at a different angle but the 3 bolts that hold it to the bracket mean it won't. Don't suppose I will get pulled over for a dim light? Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted March 21, 2009 Share Posted March 21, 2009 In the words of many a car-dealer....... 'They all do that, Sir'.......... I wouldn't worry about it - its the way it was built, so it passed construction/use regs in that form - if its good enough for the EC Government, it should be good enough for the local traffic feds.......... Quote Link to comment Share on other sites More sharing options...
western Posted March 21, 2009 Share Posted March 21, 2009 provide the number plate light is lit when switched on, doubt you'll have any problems. Quote Link to comment Share on other sites More sharing options...
Madcowz Posted March 22, 2009 Author Share Posted March 22, 2009 I managed to bend the bracket holding the number plate lamp back into shape so that the light now shines on the plate. It had been whacked before and was bent back against the tub so didn't shine on the plate at all. Quote Link to comment Share on other sites More sharing options...
