AJL Posted February 22, 2006 Share Posted February 22, 2006 Currently on my 110 i've got OME 2" Lift Springs and Shocks all round Having recently fitted an ARB Type (TJM) heavy duty bumper and 8274 with wire cable all that weight out front has had noticeable effect on handling. Whilst the front end hasn't sagged the is noticeable wallow. What springs can i stick under the front end so there is little or no movement as before. Would HD rear Disco springs do the trick? Quote Link to comment Share on other sites More sharing options...
white90 Posted February 22, 2006 Share Posted February 22, 2006 a pair of OME 763 would probably do the trick, but may be too firm. Nick (tangoman)had a pr he was clearing out a while ago. Got any pics of it all fitted? Quote Link to comment Share on other sites More sharing options...
AJL Posted February 22, 2006 Author Share Posted February 22, 2006 Currently on my 110 i've got OME 2" Lift Springs and Shocks all round Having recently fitted an ARB Type (TJM) heavy duty bumper and 8274 with wire cable all that weight out front has had noticeable effect on handling. Whilst the front end hasn't sagged the is noticeable wallow. What springs can i stick under the front end so there is little or no movement as before. Would HD rear Disco springs do the trick? OK thanks Tony i'll post pics shortly. Didnt bother in the end with the original winch bumper plan as i'm not prepaired to 'persuade' someone to take my cash plus i've now got mega frontal protection which is better for my application ie night shooting (bumping gates open etc) Quote Link to comment Share on other sites More sharing options...
white90 Posted February 22, 2006 Share Posted February 22, 2006 good call really. for your application full protection will be more suited. Quote Link to comment Share on other sites More sharing options...
AJL Posted February 22, 2006 Author Share Posted February 22, 2006 Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 22, 2006 Share Posted February 22, 2006 "insert an 8274 insult here" Quote Link to comment Share on other sites More sharing options...
white90 Posted February 22, 2006 Share Posted February 22, 2006 James,I wish I had kept my 8274 and not purchased a lump of pig iron called a MM then fitted the POS to my 90 O the power of hindsight. Stephen How honest of you Stephen! nice job James looks ace. Quote Link to comment Share on other sites More sharing options...
AJL Posted February 22, 2006 Author Share Posted February 22, 2006 James,I wish I had kept my 8274 and not purchased a lump of pig iron called a MM then fitted the POS to my 90 O the power of hindsight. Stephen Oh Stephen!! I never thought i'd see the day Pitty your not in the UK because the only place for a MM having once been a 'non' proud owner of one is Ebay i still cant get over mine sold for £860 second hand Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 22, 2006 Share Posted February 22, 2006 Nice bumper James Are those Black Rat recovery hooks? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 22, 2006 Share Posted February 22, 2006 I think a moderator called white90 may have altered my original post In fact completely :P Fortunately there is an "edit" function though Quote Link to comment Share on other sites More sharing options...
white90 Posted February 22, 2006 Share Posted February 22, 2006 Slander of the highest order Mr Monster! luckily James and i quoted your real reply. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted February 22, 2006 Share Posted February 22, 2006 FWIW... on my 300Tdi 90, i've got a (BWB copy) ARB bar/winch mount with an 8274 (and steering guard), so am front end heavy too. I'm running OME 763 up front, and 762 on the back (or t'other way around.. ), but it gives a good ride and doesn't seem to wallow much (it is a rather lardy 90, as Andy M will vouch for! ) with full external cage and all the toys on board! on my 110, when i had my 8274 and camel type nudgebar (similar weight to the BRB bar) i stuck a set of 90 HD rear springs in, which was great for handling, but left the front end a little "high" (compared to the back on standard SW HD springs... had i fitted some "decent" springs on the back with a 2 or 3" lift then it would have looked "normal") I reckon you'll be OK with stock 90 rears on the front, or 90 HD rears if you have longer/stiffer rear springs to keep it looking "normal"...ish.. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted February 22, 2006 Share Posted February 22, 2006 Slander of the highest order Mr Monster!luckily James and i quoted your real reply. The real-ly edited one you mean? Give up, it was you, I recognised a couple of things Quote Link to comment Share on other sites More sharing options...
