Goober Posted March 26, 2009 Share Posted March 26, 2009 hi, when i switch my wipers on they dont work on the first switch, then the second switch they work but slowly. they squirt water and wipe slow when pulled back. could this be the motor thats gone? also wher abouts is it? 1987 defender Quote Link to comment Share on other sites More sharing options...
western Posted March 26, 2009 Share Posted March 26, 2009 wiper motor is located behind the dash lower left corner, remove the dash end handle 3 screws, 1 behind the LR oval badge, undo the 4 scres that hold the corner in place & you'll see the motor, could be a sticking drive rack or partly seiezed wheelboxes that the wiper arms fit on or a partly siezed motor. Quote Link to comment Share on other sites More sharing options...
Goober Posted March 27, 2009 Author Share Posted March 27, 2009 wiper motor is located behind the dash lower left corner, remove the dash end handle 3 screws, 1 behind the LR oval badge, undo the 4 scres that hold the corner in place & you'll see the motor, could be a sticking drive rack or partly seiezed wheelboxes that the wiper arms fit on or a partly siezed motor. I located it today, how do i go about repairing it? would i have to dismantle the motor and remove if from the dash? Quote Link to comment Share on other sites More sharing options...
steve_d Posted March 27, 2009 Share Posted March 27, 2009 I don't know this setup but from the comment earlier about wheelboxes then have a go at this. Is there a tin lid affair on the top of the wiper assembly? If so then you can take it off and release the drive cable from the gearbox. With the wipers pulled back from the glass can you push and pull the drive cable and make the wipers turn. If you can then that part of the mechanism is good. If it is very stiff then that may be your problem and is not easy to get at. Take the wiper mechanism off and take it to the bench to strip down. It probably needs a good clean and fresh grease but you should also check and clean the commutator and brushes. Steve Quote Link to comment Share on other sites More sharing options...
jules Posted March 27, 2009 Share Posted March 27, 2009 My 1990 110 the wiper's only worked on fast and it was the stork at fault it was about £40 for a new one. having said that intermittent still doesn't work Quote Link to comment Share on other sites More sharing options...
reads90 Posted March 27, 2009 Share Posted March 27, 2009 Don't even know if mine work on the 90 or 110 . Has to rain to use them. But saying that will get to test them in a few weeks as Jules is coming over and always rains when he is here Quote Link to comment Share on other sites More sharing options...
Goober Posted March 27, 2009 Author Share Posted March 27, 2009 My 1990 110 the wiper's only worked on fast and it was the stork at fault it was about £40 for a new one. having said that intermittent still doesn't work Il have a look tomorrow and see if find anything when i strip it down. dont all functions have to work for the mot? Quote Link to comment Share on other sites More sharing options...
western Posted March 27, 2009 Share Posted March 27, 2009 provided the wipers work & the washers work, there should be no MOT problem. Quote Link to comment Share on other sites More sharing options...
