Badger90 Posted March 29, 2009 Share Posted March 29, 2009 right.. does anyone know if there is any differnce in the main shafts of a LT77 to the R380 and if it is prossible to put a LT77 main shaft in a R380 so you can mate it to a 200Tdi engine? or are you able to shove a LT77 bellhouseing on a R380 box.. but the main shaft will be long if im correct? cheers sam Quote Link to comment Share on other sites More sharing options...
missingsid Posted March 29, 2009 Share Posted March 29, 2009 right..does anyone know if there is any differnce in the main shafts of a LT77 to the R380 and if it is prossible to put a LT77 main shaft in a R380 so you can mate it to a 200Tdi engine? or are you able to shove a LT77 bellhouseing on a R380 box.. but the main shaft will be long if im correct? cheers sam If you are lucky Dave Ashcroft (Ashtrans) will answer, if not why not just call him as they will know. * Email: info@ashcroft-transmissions.co.uk * Phone: 01582 496040 * Fax: 01582 595040 Marc. Quote Link to comment Share on other sites More sharing options...
Badger90 Posted March 29, 2009 Author Share Posted March 29, 2009 If you are lucky Dave Ashcroft (Ashtrans) will answer, if not why not just call him as they will know. * Email: info@ashcroft-transmissions.co.uk * Phone: 01582 496040 * Fax: 01582 595040 Marc. yeah i will tomorrow.. just been looking on their site.. its a dissision between auto or R380 short stick!! Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 30, 2009 Share Posted March 30, 2009 I am pretty sure a 300 version of the R380 will bolt straight onto a 200 its just the bellhousing is too long for the gearbox mounts to match up. There is a special short-bellhousing version of the R380, used in a handful of very late build special order 2.5 naturally aspirated vehicles built in the 1995 model year, which will go straight in and would be by far the best solution - if you can find one! Also please be aware that a "short stick" R380 is a Discovery version (short gearstick, vs long stick for a Defender) it doesn't mean the input shaft is shorter - it'll be no good in your Defender as you will end up with the gear lever coming up through the middle seat somewhere Quote Link to comment Share on other sites More sharing options...
