cabell Posted April 2, 2009 Share Posted April 2, 2009 My lt77 shifter rattles in 5th gear. If I put a finger on it and apply slight pressure to the side all is quite again. Is there an adjustment I can make or is there possibly a spring or something that has died? It's an early LT77, 1983 vintage. Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted April 2, 2009 Share Posted April 2, 2009 My lt77 shifter rattles in 5th gear. If I put a finger on it and apply slight pressure to the side all is quite again. Is there an adjustment I can make or is there possibly a spring or something that has died? It's an early LT77, 1983 vintage. Pull up the rubber gaiter around the gear lever - the lever itself is clamped onto a short stub from the gearbox with a single nut - I'd put money on that nut being slightly loose.... Matt Quote Link to comment Share on other sites More sharing options...
cabell Posted April 2, 2009 Author Share Posted April 2, 2009 Thanks Matt. Already checked that nut and it was good and tight. Quote Link to comment Share on other sites More sharing options...
western Posted April 2, 2009 Share Posted April 2, 2009 could be the anti rattle plunger/spring is missing or broken, it lives the the lower section ball part. Quote Link to comment Share on other sites More sharing options...
cabell Posted April 2, 2009 Author Share Posted April 2, 2009 Thanks Western, any chance you have a schematic on that? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 3, 2009 Share Posted April 3, 2009 The plunger isn't an anti-rattle device - it's there to prevent accidental selection of reverse gear. The two springs centralise the gearstick between gears. Whole thread on the stick mechanism - http://forums.lr4x4.com/index.php?showtopic=40005 Les. Quote Link to comment Share on other sites More sharing options...
danster Posted April 3, 2009 Share Posted April 3, 2009 thats an r380 think hes on about a lt77 and yes theres a spring and plunger i had to replace the nylon cup on mine because there was a lot of play in the lever may have to check and adjust the bias springs too Quote Link to comment Share on other sites More sharing options...
danster Posted April 3, 2009 Share Posted April 3, 2009 ahh but looking at the other thread thats a disco lt77 not a defender looking for a pdf that shows an exploding diagram of it but cant find one yet! Quote Link to comment Share on other sites More sharing options...
cabell Posted April 3, 2009 Author Share Posted April 3, 2009 Danster, Is the plastic cup you refered to FRC5859 "seat-ball end"? This looks like a plastic bushing that the ball at the bottom of the lever rides in. I'm thinking this could cause my problem if it's knackered. Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2009 Share Posted April 3, 2009 Thanks Western, any chance you have a schematic on that? plunger & spring listed below item 7 in the parts list, they fit in the ball section, but not shown on the diagram Quote Link to comment Share on other sites More sharing options...
danster Posted April 3, 2009 Share Posted April 3, 2009 Danster, Is the plastic cup you refered to FRC5859 "seat-ball end"? This looks like a plastic bushing that the ball at the bottom of the lever rides in. I'm thinking this could cause my problem if it's knackered. yeah that was the one my gear lever was excessively sloppy replacing that and adjusting the bias springs cured it and you can check the spring and plunger is there i presume the spring and plunger is just there to stop any small free play Quote Link to comment Share on other sites More sharing options...
