derrick Posted April 6, 2009 Share Posted April 6, 2009 doe,s anybody know where i can get the two intermediat roller bearings for my transfer box. its of a series 3 later type gearbox 1982 suffixs D Quote Link to comment Share on other sites More sharing options...
secondjeremy Posted April 7, 2009 Share Posted April 7, 2009 These are the same bearings fitted to all transfer boxes with the enlarged intermediate gear shaft which is from Series 11a gearbox suffix 'C' (I think). There is no possibility of confusion with the earlier ones as they're about half the size. The usual specialists will stock them - Craddocks, L R Series, Blanchards, Dunsfold etc. The number is 599869 (formerly 521329) If you want the shaft its 594195 (521326) Quote Link to comment Share on other sites More sharing options...
derrick Posted April 7, 2009 Author Share Posted April 7, 2009 Top man. not long joined and im loven it more & more thanks to you guys. ill wring tomorow and find how much they are thanks del. Quote Link to comment Share on other sites More sharing options...
Jon White Posted April 8, 2009 Share Posted April 8, 2009 If the bearings have broken up you will probably also need to replace the shaft and the intermediate gear. Check the bearing surfaces very carefully. You will also need new thrust washers, and possible shims too. Its worth doing properly as the intermediate gear is often responable for alot of the noise in a series transfer box. Jon Quote Link to comment Share on other sites More sharing options...
