wib Posted April 11, 2009 Share Posted April 11, 2009 hi my friend has a range rover 3.9 efi 1990 auto .the engine oil on the dip stick smells of petrol does eney one no why this is thanks .IAN Quote Link to comment Share on other sites More sharing options...
stuck Posted April 11, 2009 Share Posted April 11, 2009 For god's sake, if you have a habit sniff the filler neck not the dip stick! SORRY. Quote Link to comment Share on other sites More sharing options...
tinker Posted April 11, 2009 Share Posted April 11, 2009 For god's sake, if you have a habit sniff the filler neck not the dip stick!SORRY. could be early signs of headgasket.. Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted April 11, 2009 Share Posted April 11, 2009 Sounds like too much fuel being injected in causing bore wash i.e fuel getting into the sump Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 11, 2009 Share Posted April 11, 2009 Does it run ok or seem rich ? CTS or maybe a leaking injector, neither are good things to have wrong for long engine life Quick fix maybe 2x bottles of FORTE Injector cleaner (nothing else works as well) into 1/3 tank of fuel, go for a drive when really low and only then refill fuel Nige Quote Link to comment Share on other sites More sharing options...
Coastcard Posted April 12, 2009 Share Posted April 12, 2009 Nige, Any ideas where to get the Forte injection cleaner from. I had a look around and it seems a trade only product. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 12, 2009 Share Posted April 12, 2009 Kweith Gotts in Alton normally stock it MuddyTax in Aldershot sometimes do, ring he can get it in if out of stock Nige Quote Link to comment Share on other sites More sharing options...
zen Posted April 12, 2009 Share Posted April 12, 2009 or..you have lost a spark or two and the injectors are fine.. Quote Link to comment Share on other sites More sharing options...
