western Posted April 17, 2007 Share Posted April 17, 2007 the captive nut plates shouldn't be welded on, they are normally held in a spring clip to the lower bumper attachment, if you want new parts the details are ---------- upto chassis number 1A 619800 -- LR part NRC6994 or from chassis number 1A 619801 -- LR part ALQ710020 bolts in both are M10 x 120mm LR part NTC5401 or obtain some longer bolts & large thick washers & nyloc nuts. Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted April 17, 2007 Share Posted April 17, 2007 Western - many thanks for that! Do you know if its possible to just use the bumper bolt's with nylocs? Is there room to get the nuts on and then to get a spanner in? I'm hoping there is as this would be my prefered method of fitting the bumper. I have a local fixings supplier and I'd be able to get everything in one go. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 17, 2007 Share Posted April 17, 2007 You could do it that way BUT when they rust, and they will, what will you do to get the rusted rounded nuts off when they are at finger tip distance inside your chassis leg :angry: Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted April 17, 2007 Share Posted April 17, 2007 Good call - didn't think of that! And seeing as I'm going to have to use an angle grinder to get the old bumper off, it looks like I'm about to order some parts! Quote Link to comment Share on other sites More sharing options...
western Posted April 17, 2007 Share Posted April 17, 2007 what Walfy said, I'd use the correct plates. Quote Link to comment Share on other sites More sharing options...
Se7enUp Posted April 18, 2007 Share Posted April 18, 2007 Parts ordered - thanks for the help Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 18, 2007 Share Posted April 18, 2007 ...and make sure you use plenty of Copperslip on the threads!! Quote Link to comment Share on other sites More sharing options...
