92a Posted April 25, 2009 Share Posted April 25, 2009 Hi my 200 tdi engine almost dies when you lift off after reving it, did it before i changed the timing belt and filter, still does it now.Anyone else had this? any suggestions please Quote Link to comment Share on other sites More sharing options...
discomikey Posted April 25, 2009 Share Posted April 25, 2009 adjust the power screw on the fuel injector pump, or if your tickover is too low, sometimes you can fix it by turning that up, both are 2 second jobs really but i cant expeain the location of them properly, all i know is there is a link on this forum to tuning a 200tdi, which has diagrams and instructions on he fuel pump, including the power screw try searching in the tch archive for "200tdi tuning" and that thread should help you coupld with my information mikey Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted April 26, 2009 Share Posted April 26, 2009 Hi my 200 tdi engine almost dies when you lift off after reving it, did it before i changed the timing belt and filter, still does it now.Anyone else had this? any suggestions please Sounds like a leak in the intercooler or more likely the intercooler hoses to me... Also check for other vacuum leaks. Quote Link to comment Share on other sites More sharing options...
Orange Posted April 26, 2009 Share Posted April 26, 2009 To adjust the tick-over, turn the plastic cap on the accelerator cable where it attaches to the injector pump. How is the idle, generally? lumpy, slow....?? Quote Link to comment Share on other sites More sharing options...
92a Posted April 27, 2009 Author Share Posted April 27, 2009 To adjust the tick-over, turn the plastic cap on the accelerator cable where it attaches to the injector pump.How is the idle, generally? lumpy, slow....?? Did it in the 93 discovery and still does it in my series conversion with new "bespoke" intercooler and silicon hoses? Quote Link to comment Share on other sites More sharing options...
