wheatfielder Posted May 11, 2009 Share Posted May 11, 2009 Oil is leaking out of me rear nearside hub onto the rear of the tyre and onto the road,no oil at the front of the wheel, presumably there isnt a lot of oil to come out and it should stop dripping after a short while. Should i get this replaced very quickly? What can happen if its left for a while? Cheers all. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 11, 2009 Share Posted May 11, 2009 Could contaminate the brake shoes/drum if you have an older vehicle. Still something I would want to fix even if not, the new seal is RTC3511. I've just done mine, easy job...just a bit messy Quote Link to comment Share on other sites More sharing options...
Mike Posted May 11, 2009 Share Posted May 11, 2009 Check the stub axle where the seal seals, that can get chewed up too. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted May 11, 2009 Share Posted May 11, 2009 ... it can contaminate the disk/pad if you have a newer vehicle fwiw the leak on mine turned out to be at the gasket between the stub axle and axle Quote Link to comment Share on other sites More sharing options...
