mad_pete Posted May 24, 2009 Share Posted May 24, 2009 I've got a 4.2 V8 in my 90. It mounts in the correct position for a v8 with viscous fan. I have NA diesel rad in there ( if that matters ) as I need the oil cooler. Engine's running hot and a cowl should help with the viscous fan. Are cowls one size fits all or do I need to be a little bit cleverer than that ? Quote Link to comment Share on other sites More sharing options...
western Posted May 24, 2009 Share Posted May 24, 2009 how much distance between fan & radiator, might be able to use the TD cowling suitable modified. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted May 25, 2009 Share Posted May 25, 2009 Is the 4.2 a serpentine engine? If it is, a Defender 50th cowling should fit. That is what I am usiung with a TD rad. Quote Link to comment Share on other sites More sharing options...
mad_pete Posted May 25, 2009 Author Share Posted May 25, 2009 It's a non serpentine engine. Well actually I think it was but Jules put the other type front on. So I think that makes it not. Distance to rad from fan is 23mm Might investigate the 50th cowl anyway Quote Link to comment Share on other sites More sharing options...
