berel Posted May 27, 2009 Share Posted May 27, 2009 Hi, I have an `84 110 V8 CSW in good nick. Gear lever snapped right at base unfortunately whilst parked across a mates drive ! Fitted a new lever and detent springs. Problem is while the 1st & 2nd gears engage ok also reverse, the "gate" for 3rd & 4th is now very slack and I have to stir about to engage. I did`nt have this problem before. Any ideas what I may have missed. Thanks. Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2009 Share Posted May 28, 2009 haven't found any useful info in the workshop manual, might be a bias spring that needs adjusting to align the lever to 3rd/4th. Quote Link to comment Share on other sites More sharing options...
berel Posted May 28, 2009 Author Share Posted May 28, 2009 haven't found any useful info in the workshop manual, might be a bias spring that needs adjusting to align the lever to 3rd/4th. thanks, will relook in LR manual -- it`s a bit vague when it comes to LT95 gearbox top end detail. Have tried web sites for PDF down loads - no success so far -- maybe someone can suggest some sites I could try. Doesn`t stop me driving the old girl --- my granddaughter christened her Berel. Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2009 Share Posted May 28, 2009 as you mention detent sprins is the ball fitted that acts with the springs? Quote Link to comment Share on other sites More sharing options...
berel Posted May 31, 2009 Author Share Posted May 31, 2009 as you mention detent sprins is the ball fitted that acts with the springs? yes. ballbearings remained in place ok when i removed top plate. local dealer suggested i replace springs - they advised that of the three springs to be replaced , the reverse spring has greatest resistance. they supplied replacements and identified the reverse spring. all fitted as directed - still puzzled. Thanks for feedback. Quote Link to comment Share on other sites More sharing options...
pat_pending Posted May 31, 2009 Share Posted May 31, 2009 There is no bias on an lt95 box. The lever can float between 1/2-3/4 in neutral. The reverse gate is a spring loaded "flap" on the reverse selector shaft. You have to push the lever across to overcome this. There should be a felt ring under the gear lever locating ring that stops the gear lever flopping about. No need to remove the top cover to replace the gear lever and no need to replace the detent springs either. Possible problems? You knocked one of the detent springs into the box when you fitted the top cover. The grub screw that fits in the r/h/s of the housing and stops the lever rotating, is worn or missing. Coincidentally with the gear lever snapping, one of the roll pins that hold the selector jaws and forks on the shafts has sheared. Quote Link to comment Share on other sites More sharing options...
berel Posted June 2, 2009 Author Share Posted June 2, 2009 There is no bias on an lt95 box. The lever can float between 1/2-3/4 in neutral. The reverse gate is a spring loaded "flap" on the reverse selector shaft. You have to push the lever across to overcome this. There should be a felt ring under the gear lever locating ring that stops the gear lever flopping about.No need to remove the top cover to replace the gear lever and no need to replace the detent springs either. Possible problems? You knocked one of the detent springs into the box when you fitted the top cover. The grub screw that fits in the r/h/s of the housing and stops the lever rotating, is worn or missing. Coincidentally with the gear lever snapping, one of the roll pins that hold the selector jaws and forks on the shafts has sheared. as the lever snapped right at the "ball" of the selector there was nothing to grip & years of gunge firmly held it in. had no option but to remove top cover. springs all recovered & new ones bedded in with grease, all gears worked perfectly - i simulated action of selector before fitting - all worked ok. grub screw fitted ok. however you have made me think about the felt ring under gear lever locating ring. a composite material (not felt ) ring was supplied with new gear lever, on checking this today, i`ve found that this has literally disintegrated, presumably when it was torqued down when locating ring was refitted . I will replace with a felt or similar ring and hopefully will take up play in gearlever. thanks to all for input, want to get it better as we enjoy driving the lancashire and yorkshire dales & that means lots of gear changes !! -- in between pub stops ! Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted June 3, 2009 Share Posted June 3, 2009 Did you check the ball parts of the gearlever were the same? There are two sorts Quote Link to comment Share on other sites More sharing options...
Guest fred4x4 Posted June 3, 2009 Share Posted June 3, 2009 Hi, I have an `84 110 V8 CSW in good nick. Gear lever snapped right at base unfortunately whilst parked across a mates drive ! Fitted a new lever and detent springs. Problem is while the 1st & 2nd gears engage ok also reverse, the "gate" for 3rd & 4th is now very slack and I have to stir about to engage. I did`nt have this problem before. Any ideas what I may have missed. Thanks. hi I had an L95 gear lever problem on the lower end ball some have a flat on one side and orthers have a flat on both sides hope this helps Quote Link to comment Share on other sites More sharing options...
berel Posted June 3, 2009 Author Share Posted June 3, 2009 hi I had an L95 gear lever problem on the lower end ball some have a flat on one side and orthers have a flat on both sides hope this helps thanks, have fitted a new slightly thicker gasket below lever location ring, seems little tighter and less movement, will test run tomorrow. i appreciate that lever movement will always be a bit sloppy. Quote Link to comment Share on other sites More sharing options...
