moony123 Posted June 9, 2009 Share Posted June 9, 2009 hi all got a side exit on my series 3 tdi is there something you can get to protect my wing? i have the exhaust coming straight out of my wing at 67mm need an insert 70mm to 90mm as ive seen in mags on other landys but unsure of the name of them can any1 help cheers Quote Link to comment Share on other sites More sharing options...
tony109 Posted June 9, 2009 Share Posted June 9, 2009 hi all got a side exit on my series 3 tdi is there something you can get to protect my wing?i have the exhaust coming straight out of my wing at 67mm need an insert 70mm to 90mm as ive seen in mags on other landys but unsure of the name of them can any1 help cheers Keeping the exhaust out of halms way is not that easy with some systems.. The standard exhaust on the series 1 and 2 went underneath the front bulkhead outrigger. The later series 2/3 goes down beside the engine but still dips below the engine xmember, the lowest point and very easy to ground. I passed my down pipe through the bulkhead outrigger.. In this location its been completely safe.. I incorpoarted this mod into my new chassis.. The exhaust exits infront of the rear wheel.. Ive seen exhausts that exit through the rear body and Im sure you can make or have made a body insert.. Look in the LR mags and Im sure you'll find plenty of aftermarket kits or firms offering what you want. But what have you done with the downpipe end.. Does yours pass under or above the engine crossmember? Quote Link to comment Share on other sites More sharing options...
missingsid Posted June 10, 2009 Share Posted June 10, 2009 Hi Moony123, I just pinched this off Tractorboy16's Hybred thread. Looks to be from D44? Marc. Quote Link to comment Share on other sites More sharing options...
ian_s Posted June 10, 2009 Share Posted June 10, 2009 I passed my down pipe through the bulkhead outrigger.. In this location its been completely safe.. I incorpoarted this mod into my new chassis.. i thought about doing that on mine, but i was worried about weakening the outrigger too much Quote Link to comment Share on other sites More sharing options...
moony123 Posted June 10, 2009 Author Share Posted June 10, 2009 cheers lads i'm sending mine through the front wing at the bottom save running it all underneath just had a pipe fabricated to suit the right angel Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted June 10, 2009 Share Posted June 10, 2009 A picture says a thousand words.... Can you show the finished article? Quote Link to comment Share on other sites More sharing options...
