reads90 Posted June 14, 2009 Share Posted June 14, 2009 Ok have a problem with my interipr light in my 110. Here is what happens and what i have done. Interior light works with the on switch but does not work in the switch posiition for working when the doors are open. Replaced the door pluger switches, Nothing . And checked cable which shows that there is power going to the door switches. And also check the switches are earthing which they are. Also tried to earth the switch from another area, still not working . . Took the light out and checked the cable and connections in the light and all is ok. And checked the interior light switch fuse which is fine . Still not working Can anyone shed some light on what may be the problem Cheers Ali Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 14, 2009 Share Posted June 14, 2009 The only components in the system are the 12V feed, light unit, the selector switch bottom right in the dash, and the door switches. I would be checking the mode selector switch in your case, it may be that it has failed internally. Quote Link to comment Share on other sites More sharing options...
western Posted June 14, 2009 Share Posted June 14, 2009 300Tdi's don't have a dash switch, it's part of the light unit. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 14, 2009 Share Posted June 14, 2009 Fair play, didn't know that. Maybe something inside the switch part of the light unit then? Quote Link to comment Share on other sites More sharing options...
